How high should my tractor lift these?
   / How high should my tractor lift these? #1
dantegy
I have recently purchased a Mitsubishi 210D 4x4 tractor. Everything is working on it, the problem is with the attachments. I am trying to find out about how high am I supposed to be able to lift a 4 foot king kutter bush hog and where should I keep it as far as height goes, are all of the lift pins at a standard height on a cat 1 tractor attachment. I can only get it 8 inches high with the lift, should this be higher? I also have a 5 foot king kutter box blade, how high should I be able to lift this, Right now it is about 14 inches off the ground.
~Daniel T.
   / How high should my tractor lift these? #2
Have you tried adjusting your top link? If you take it up some, the implements should lift higher. I have a short one for my disc and mowers and a longer one for my cultivator and middle buster to adjust them to where I want them.
   / How high should my tractor lift these? #3
Can't tell if you're talking about cutting height or height of the rear wheel when you're transporting it. Most bush hogs have a max cutting height of about 10", which means if you disconnect the toplink and raise the arms to their maximum height, you'll get about a 10" high cut. Unless you're mowing a sod farm you probably don't want to be mowing with the toplink connected- either use a chain or reconnect the toplink when you need to transport it.
What are you trying to do with the BB that would require lifting it higher than 14" off the ground?
   / How high should my tractor lift these? #4
I must be odd. I always cut with the toplink connected on my Bushhog. The cutter even has a sliding clevis type connection on top for that. I just leave the top link long enough to let it slide. I don't have a sod farm.
   / How high should my tractor lift these? #5
Pto shaft ain't bottoming out is it?
soundguy
   / How high should my tractor lift these? #6
Welcome to the forum Dantegy. Everything is most likely fine with your tractor. The King Kutter rotary mowers 3 point configuration is a bit unusual and difficult for smaller tractors. The lift pins are mounted rather high limiting how much you can raise the mower. What I and others with the same problem have done is to add an additional set of lift pins lower on the frame. The original configuration is also rather wide so I mounted the new pins facing inward. Once you make this minor modification you will find it to be a good mower.
MarkV
   / How high should my tractor lift these? #7
Bushhogs come with that nice flex link on top. Cheaper brands don't have that. So if you leave the toplink connected it creates a rigid connection between the mower and tractor. As you drive over the crest of a hill, that link will lift the back wheel off the ground. As you drive into a trough, that link will try to foce the rear wheel into the ground. Either the wheel digs into the dirt or the mower itself has to flex to accomodate that force. You can use a chain as the toplink and leave some slack in it. That accomplishes the same thing that your flex link accomplishes. It lets the mower freely roll over the terrain.
   / How high should my tractor lift these? #8
I appreciate all of the insight, my land that i am brush cutting is in need of a lot of dirt so I have low spots. Last time i cut it I dipped down in a low lying area (with top link attached) as i went upward with the tractor, the attachment and tractor v'd into the trench and my 7/8 pin that connected my top link to the attachment snapped in half so I shut it down thinking that I just couldn't get attachment high enough, but after your replies and the contours of my land the chain sounds like my best alternative to the stiff top link connection. Thanks a lot.
~Dantegy
1981 LUFKIN 41 FLATBED (A53843)
1981 LUFKIN 41...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2015 Kaeser M114 100psi Towable Air Compressor (A51691)
2015 Kaeser M114...
2025 CFG Industrial STSD10 (A50123)
2025 CFG...
2012 Diamond Cargo Enclosed 24FT T/A Cargo Trailer (A51694)
2012 Diamond Cargo...
