rekees4300
Elite Member
This is from my JD X500 Owner's manual
The following recommendations will produce the best lawn cut quality and appearance:
. Keep mower blades sharp. Dull blades will tear grass; tips of grass will then turn brown.
. Cutting grass too short may kill grass and let weeds grow easily. The suggested finished cut height range is 44 - 70 mm (1.75 - 2.75 in.).
. Adjust cutting height to remove only 1/3 of the grass at a time.
. Do not mow wet grass.
. Mow grass often. Short grass clippings will decay quickly.
. Mow with engine at full throttle.
. Adjust travel speed to match mowing conditions:
. Travel at slow speed when you mow thick, tall grass, make sharp turns or trim around objects.
. Travel at moderate speed when you mow thin grass.
. Use a different mowing pattern each time you mow. Overlap mowing paths 50 - 100 mm (2 - 4 in.).
. Drive over ridges and through shallow ditches straight-on, not at an angle.
