how hard to wire in concrete block?
   / how hard to wire in concrete block? #21
2manyrocks
Is there only one breaker in that panel?
If so I'd move it out side run new wires to the breaker panel elsewhere.
and ask forgives if the inspector catches it just my opinion.
tom
One 200A breaker.
   / how hard to wire in concrete block? #23
One 200A breaker.
If the existing panel is raintight move it out side if not replace it.
Inside put a female connector on the original threads and continue conduit down to an LB and in to the back of the new/ moved panel through the block replace wire with longer ones to the main panel.
tom
   / how hard to wire in concrete block? #25
The fire department would also much prefer to see that switch on the outside .
The fire department generally trumps the building dept.
Yep its easier for the owner to get reconnected by not pulling the meter !
tom
The label says it's rain tight. Got all the block laid today. I stayed up late tearing everything out that was in the way of laying the block and ain't much good for nothing right now.
   / how hard to wire in concrete block? #27
2manyrocks
I didn't think of it till last night if you have a main breaker in the other panel you don't actually need one before it.
tom
I had the block layers lay the block without extending the walls and it looks fairly proportional. So I will have to deal with the electrical box as I go along.
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
2019 Freightliner Sprinter 1500 Van (A50323)
2019 Freightliner...
UNUSED FUTURE MINI EXCAVATOR HYD WOOD DRILL (A51244)
UNUSED FUTURE MINI...
Yamaha Golf Cart (AS IS) (A50774)
Yamaha Golf Cart...
