How hard is this on my tractor?
   / How hard is this on my tractor? #1
Beeenvenue
Ennis, TX
Kioti 3510SE HST
I have a kioti CK3510 and very very hard packed clay. It is full of ruts, etc. While bushogging, I have my teeth rattled and it can actually hurt being thrown into the armrests from some of the jolts. My loader bounces a couple of inches. I do slow down but even at mid travel hst in low range I can bounce that much. Am I hurting anything?
   / How hard is this on my tractor? #2
Go slower. It's not a race. Take your time, don't beat yourself or the tractor too much.
I see people on videos brush mowing so fast for whatever reason that I really struggle understand why. Most of them actually leave an awful finish on the brush mowing job.
   / How hard is this on my tractor? #3
Shouldn't anything at first but after while something might loosen end up costing $$$'s,after next rain and ground soft just back drag rough spots with bucket.
Just got a box blade for my drive, thinking about dragging the whole 14 acres on a very light tilt - just to knock down the ridges
   / How hard is this on my tractor? #5
A regular diet of that WILL probably take it's toll. I bought a 12 ton ZOOM BOOM that had a life carrying Steel Coils around a Steel Yard. They would go too fast through pot holes in the yard, eventually breaking off the front (SPICER) axles. No matter how well built, such continuous torture will break something!
   / How hard is this on my tractor? #6
Hey, today's today's trend!
Folks want to get there B4 they leave.
You see it on the roads every day so why not on a tractor.
   / How hard is this on my tractor? #7
And then when something happens it's all well boo-hooo! Life is so precious! Then why don't they drive accordingly? SPEED always makes things worse.
   / How hard is this on my tractor? #8
Sounds like you are going way too fast. Slow down untill both you and your tractor are comfortable.
If it hurts the tractor to continue doing this.... Sounds like you are going to find out. On some tractors it can be a very expensive fix
   / How hard is this on my tractor? #10
You can try your Box Blade. Smoothing rough pasture usually requires several implements used in succession.
T-B-N ARCHIVE: smoothing rough pasture site:tractorbynet.com - Google Search
So we have about a 3 acre field that is currently a mixture of grass and weeks that we mow at 3.5” high. Problem is it’s a old tobacco field that still has some of the ridges left in place from the previous owner. They are not terrible but enough we need to mow slow or it makes you sick going over them. So my plan is to spray round up next weekend then by end of month start disking and breaking up the soil like in a X pattern or going against the ridges. So after This what is the best implement to smooth and even everything back out? Once done I will use a cultipacker to smooth and press the dirt then spread new grass seed.
A week after you spray, mow as short as possible: "scalp."
Few with Disc Harrows adjust them after putting them to use. If you first process the field two or three times (depending on the weight bearing on each of your disc pans) to loosen ridges, then adjust gang angles less aggressively in increments, the disc may meet your needs solo.
Moist soil will make your project go faster.
Adjust Top Link to vary disc weight distribution. Shorter = more weight on front gangs. Longer = more weight on rear gangs.
More weight on front disc gangs throws dirt OUT. Use on ridges.
More weight on rear/wider disc gangs gathers dirt IN. Straddle the swales.
The faster you disc the more dirt is moved.
As the field is smoothed, adjust Position Control hydraulic lift so disc is in lighter contact with the soil.
Most pasture grass roots penetrate 7" to 9". Most pasture grass roots survive vigorous disc processing if rain arrives not long after.
If you elect to overseed I highly recommend a <$10.00 soil test and soil amendment per test result(s) prior to seeding. You need to inform test agency what variety of grass you intend to plant for optimum amendment recommendations.
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52128)
Mitsubishi FG35...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
International 133 6 Row Cultivator (A50514)
International 133...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2020 VOLVO VNL64T740 TANDEM AXLE MID ROOF (A51222)
2020 VOLVO...
