How fast do you mow with a rear finish mower?
   / How fast do you mow with a rear finish mower? #1
tow653
Gasconade County,Mo
New Holland TC29,Ford Jubilee
I know there are a lot of variables,but generally how fast do you mow with rear finish mower. Extremly dry here,where isn't it?,so went from 3.4 to4.9 mph this afternoon. Had plenty of power,but slowed it back down due to roughness. Using NH TC29 w/ woods FM660. Like I said,plenty of power,but don't want to tear tractor and mower up. Just looking for comparisons on how fast others mow. Thanks,Tim
   / How fast do you mow with a rear finish mower? #2
I mow in 5th gear most of the time with a allis chalmer 170, woods rear mower RRM 990 i think that what it is. You can cut wet or dry.
   / How fast do you mow with a rear finish mower? #3
I mostly go as fast I can without having the mower bouncing or banging around (for the mowers sake)- On my Hydro I run Med range and just a little bit of pedal.
   / How fast do you mow with a rear finish mower? #4
i never ran a rear finish mower, but have run just about every other type. my answer would be as fast as you want/can without bouncing the you, the tractor, or the mower all over rough ground and still get the quality of cut you want. if the ground is rough, you risk more wear/tear on equipment and you and quality of cut will be poorer if you go too fast. if the ground is smooth, but the grass is high/thick, your quality of cut will suffer. it is more of a feel thing you develope then a exact m.p.h. someone can give you. one of the hardest things on equipment/rfm with going too fast on rough ground is the castor wheel bearings. at the golf course i use to work at, all of the rough mowers we had would go through those castor wheels a bit. if you got going too fast over rough ground and looked back, you could see those castors just bouncing and jarring all over the place on the bumps. that's hard on them. next thing to go would be stress cracks usually near weld/supports. with all this in mind you should develope your own feel for proper speed on the ground you are mowing. good luck.
   / How fast do you mow with a rear finish mower? #5
My tractor has 12 gears and I usually run the finish mower in either 6th or 7th gear. In 7th the mower bounces all I want it to with it's solid tires plus it's about as bouncy as I want to be on my tractor in my yard (about 6 acres I keep cut as a yard).
   / How fast do you mow with a rear finish mower? #6
As already said, there are variables. But, generally speaking, 3rd or 4th gear. (my 2600 is an 8 speed)
   / How fast do you mow with a rear finish mower? #7
I run my NH 1720 usually in 2nd range 3rd gear @ 2400 rpm...
According to my owners manual that computes to around 3.5 mph...
I can run in 2nd range 4th gear but it can get a little uncomfortable @ 4.5 mph...
My ground in the back is even rougher and I have to go back to 2nd gear @ 2.8 mph...
The tractor has 23.5 pto hp and pulls my 6' woods prd fine...
It is a very good rfm...
2nd range, 2nd gear is where I came up with the 3.4 mph
   / How fast do you mow with a rear finish mower? #9
High range 1st gear about 4 mph at 2,000 RPM. It's hard to figure as Massey doesn't provide figures based on 24" tires only 28". I can go up a gear but I like my spine the way it is. My best guess is that I can mow about 2 acres an hour with a 7 foot Woods Finish mower.
   / How fast do you mow with a rear finish mower? #10
As others have said, not fast enough to be hard on the equipment. That varies on different parts of our place. If the grass isn't too tall there are places that I can roll along pretty fast. There are flat places where I use high range because the mid range isn't fast enough at PTO speed. The HST and varying terrain make it difficult to accurately give a mile per hour speed.
A good piece of the yard has been torn up for the last couple of months due to a regrading project. I haven't mowed the usual area since getting the 6' RFM. When I was using the 5' RFM it took me between 1-1/4 and 1-1/2 hours to do a little over 2 acres. It goes faster with the larger tractor and deck.
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
1.5 Rolls of Red Brand Barb Wire (A50515)
1.5 Rolls of Red...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
Killbros 260 Seed Conveyor (A52128)
Killbros 260 Seed...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
