How far would you drive a tractor?
   / How far would you drive a tractor? #31
Depends, On the back country farm roads, 15 miles is no problem. On the 2 land HWY only a few or so; on four land divided, only crossing the road.
   / How far would you drive a tractor? #32
One other consideration is insurance. If the tractor is covered under a standard homeowners policy, then coverage only applies to incidents on your land. My agent told me
to keep it on my land so driving anywhere else is off the table for me. Yours may be different but wanted to bring it up.
THIS!! I wouldn’t drive a mile without the right kind of coverage.
Otherwise, I wouldn’t hesitate to drive my tractor on the road with flashing lights and SMV signage.
   / How far would you drive a tractor? #33
Chase cars are horrible ideas.
Maybe not so bad on a 4 lane road, but on a 2 lane road they quadruple the amount of distance (and time) the passing cars need to be in the oncoming traffic lane.
They just create a dangerous situation.
I disagree. The chase vehicle is an EXCELLENT idea if you must do this at all. I've used that approach many times on shorter distances.
Several reasons: 1) The chase car can run with flashers/emergency lights on the whole way. Secondly it has a horn with which to warn you of things. Thirdly, the chase car/truck can vary the distance behind you as needed for a space and amount of buffer for you.
All that said -- I think you will have some trouble mowing 3ft high pines with a bush hog and that size tractor. Probably a practical approach would be to hire it done ONCE and then figure out what you do in the longer run. Surely to heavens someone local can haul your tractor, loan you a trailer, etc.
   / How far would you drive a tractor? #34
I’ve roaded both my Kubota BX and JD 2025r about 7 miles. I have both a yellow light bar and the factory flashers. I agree, no chase vehicle. Do you have other routes available? Does the 4 lane have wide shoulders. If not I wouldn’t do it. Farmer got killed 2 years on a 4 lane near here and he was in a pretty good sized JD.
The only person ever killed in a car-hits-tractor incident that I ever heard of in WV had no chase car and very ineffective flashers. And the person killed was on the back, not in the driver's seat. While I am bothering to comment, none of us should be pushed around by our damnable insurance. Just do what you gotta do.
Thanks ALL replies! I do have good flashers & triangle. Quite a lot of tractors in this area and sherriff's department put up large watch for tractors signs. I would pull over every chance. I'll see if I can find someone in area who will bush hog it first, friend with trailer second, driving it last resort.
   / How far would you drive a tractor? #37
4 Lane?? Not a chance in HE!! If you can't haul it, hire either the hauling or the mowing.
   / How far would you drive a tractor? #38
We should all be aware of how dangerous auto traffic on paved roads in our area is and act accordingly.
   / How far would you drive a tractor? #39
Yes. There is one guy around here that likes to drive his tractor down the road at night with no lights. People that live around here are aware of it but some night he's going to run into someone that is not aware of his foolish behavior. Every time I see it I'm tempted to call the cops but I know that by the time they get out here he will be where he's going with the tractor off. Fortunately for him I do not know where his farm is and I've never seen the tractor parked anywhere. He probably keeps it parked inside. I'm not usually critical of farmers and their tractors but this guy is different, eventually he's going to kill someone.
   / How far would you drive a tractor? #40
We have more tractors on the road around here now because the Amish are now driving tractors with trailers like their trucks. I guess they're giving their horses a break.
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
1999 Thompson H3 S/A Towable Vacuum Water Pump (A59228)
1999 Thompson H3...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Kubota Z232 (A60462)
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
