How far would you drive a tractor?
   / How far would you drive a tractor? #11
I’m used to driving larger tractors and combines much longer distances and love the 4-lane stretches without worry because of the size. That being said, on such a small tractor I’d do what post#2 said plus a good rear view mirror and have at it.
Post 2 must have been deleted.
Having said that, I drive on paved and dirt roads to get to my fields all the time, pulling various implements, some real wide, some not so wide. been doing that for years.
So long as you meet your state requirements for warning lights and SMV triangles, you are all good.
Often my trips are after the sun goes down and believe me, I'm all lit up. Just takes a little common sense on your part, allowing traffic to get around you when possible and a good attitude towards idiots.... and today, there are a lot of idiots.
I can run at 22 mph but usually I run 18-20 mph. I'm in no hurry anyway. I like to rubberneck.
Keep in mind that you cannot operate any tractor on a limited access highway or Interstate without express written permission from your state.
I've had a few 'incidents' in my years of going on paved and dirt secondary roads. It's usually someone who is in big hurry to get nowhere and they usually loose. One, I'm bigger than they are and two, I have the right of way as farm equipment.
One of my larger fields is 10 miles from the farm.
Remember one time, I had some kid attempt to pass me on a dirt 2 lane and I was pulling a 12 foot wide implement and had no where to pull over. He got in a big hurry and went in the ditch. I called the Sherriff and told him where he was and continued on as his cussing faded away... When I came back through I could see the wrecker tracks, that was it.
   / How far would you drive a tractor? #12
Heck now that I remember it I have driven a rubber tracked crawler that only goes 5 mph about 7 miles on a highway before. I drove it a couple miles down a busy 4 four lane road in the Houston city limits. Even went 1/4 mile or so down the tollway.
   / How far would you drive a tractor? #13
Chase cars are horrible ideas.
Maybe not so bad on a 4 lane road, but on a 2 lane road they quadruple the amount of distance (and time) the passing cars need to be in the oncoming traffic lane.
They just create a dangerous situation.
   / How far would you drive a tractor? #14
About ten years ago I didn't have a trailer large enough and drove the tractor I bought home about 110 miles across state lines. I was on a fairly major highway and went through several towns.
Best thing about that is you can swing through McDees for a burger and if you need fuel, just pull up to the fuel pump. I do both all the time of I don't have anything wide on the back that is...
   / How far would you drive a tractor? #15
I don't think the chase car is a good idea. It blocks the view of the traffic coming upon you and they won't be able to see the SMV sign or the beacon. 5 miles I'd do, the 15 miles not so much and on 4 line highways, definitely not.
You're talking about over an hour on the road one way. I'd check to see if there is someone in her area that would do it. It might be cheaper and all around easier to hire someone.
Always respect others opinions, and certainly if you don't drive the tractor there is a 100% chance nothing bad would happen.
I have driven well over 50 miles many times, the four lanes where people can pass were always the least of the challenge. On the two lanes, once we stacked up 5 cars, we would find a place to pull over and let them pass, then start up again.
I would again vote for an escort, following with hazards on. is about as safe as it gets. Should you have trouble, you will also have help (or a ride if you just want to abandon it!!)
Best,
ed
   / How far would you drive a tractor? #16
Far as I'm concerned, the BEST thing about driving a tractor to and from is the ability to check out everything (rubberneck). I can look at crops, check out the neighbors and be nosey all while motoring along at a sedate speed.
   / How far would you drive a tractor? #17
I wouldn’t be happy about driving a tractor 15 miles in any condition but through heavy traffic no way. Could you do it early in the morning/late at night and avoid the traffic?
   / How far would you drive a tractor? #18
I don't even take into account traffic. One, I sit higher than they do (almost as high as a semi truck) and two, I weigh about 4 times as much as they do, maybe more. Finally, I have the right of way as an ag vehicle, something that people in cars forget.
Had an idiot tailgate me a year or so ago, was driving into town to get to one of my fields on the other side and had nothing on the back (was going to pick up an implement I had left there and this clown was about 3 " from my drawbar and I thought to myself if I powershifted down and the tractor speed dropped real quick, how his plastic grill would look impaled on my Class 3 drawbar...
Assured clear distance don't matter, tractor, car or whatever. No one needs to be in that big of a hurry.
   / How far would you drive a tractor? #19
I have a John Deere 3038. My 94 yo Mom lives 15 miles away, most of it is moderately heavy traffic (about 5-6m. heavy 4 lane traffic). I don't have a trailer (don't want to rent truck&trailer, rather pay someone to do the work). I have a bush hog, she has about 15 acres really needing cut. 3 ft. pines growing all over it).
Top speed is about 12-13mph. Would you drive it over there?
If all back roads or 5 miles I'd do it without question.
I would make sure the tractor was in 2 wheel drive and head that way. A bit over a hour or so it sounds like. If your nervous about the higher traffic area get someone to follow you for that section, they could hang back far enough to allow passing if thats a issue.
   / How far would you drive a tractor? #20
One other consideration is insurance. If the tractor is covered under a standard homeowners policy, then coverage only applies to incidents on your land. My agent told me
to keep it on my land so driving anywhere else is off the table for me. Yours may be different but wanted to bring it up.
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
2014 Ford F-150 Pickup Truck (A53422)
2014 Ford F-150...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
1994 International 3800 Bus (A54814)
1994 International...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
