How far to put guage wheels behind LS Rake
   / How far to put guage wheels behind LS Rake #1
deere_x475guy
Eaton Rapids, MI
JD 4110
I am going to fabricate a bracket to hold some guage wheels behind my LS Rake and not sure how far back to put them. Does anyone have suggestions?
   / How far to put guage wheels behind LS Rake #2
6" to 8" behind the curve of the tines to the leading edge of the wheel.
   / How far to put guage wheels behind LS Rake #3
I have a Woods rake with wheels; can't back up with rake on the ground because the wheels won't 'castor' - they go part way around then hit the rake. What I'm trying to say is that I'd set them back just far enough so that they swivel around without interference.
Ok great thanks guys. I wasn't sure if there was an optimum distance to keep the dips from happening.
   / How far to put guage wheels behind LS Rake #5
The further back the gauge wheels the fewer dips you will have. It will do a better job grading level. However you need to be practical. My neighbor has a Woods rake that I have used a few times and as stated above the wheels are too close to the tines and won't swivel all the way around. Even when moving forward the rake does not grade as well as my rake with the wheels set further back. I think the 6-8" between the back of the tine and the front of the wheel that Junkman mentioned sounds good.
Remember, there is a reason that road graders are so long.
Good Luck
Thanks Kevin, that is my plan.
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2012 International Prostar (A56438)
2012 International...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2015 Ram 1500 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 Crew...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 Peterbilt 389 Semi (A59814)
2012 Peterbilt 389...
