megotatractor
Veteran Member
Anyone used a lawn roller to smooth a lawn that is so bumpy it shakes your insides to death? As many have complained my 2210 is a rough rider. I often consider a roller but am not sure if it would help at all. I'd have to do any rolling in the early spring or after a heavy rain as the bumps are like concrete otherwise. My current solution is to let almost all the air out of my HDAP (utility ATV tires) and run at about 5 psi to "float" around the yard. though if I get going too fast it still starts to do a horseybounce thing. And I wonder if it might make my yard bumpier with such low tire pressures since hard tires would seem like they might roll the bumps out a little?? trouble is the hassle of reinflating the tires to use the FEL. It s either a roller or I get a UTV with a towable mower and that would use a LOT more gas than my economical diesel tractor. Maybe a low flying helicopter???
Yes, yes, I know all about X series seat conversions. Sounds easy but doing is another. Not sure how well that seat suspension would hold up on my hillside yard.
