etpm
Veteran Member
- Joined
- Jun 30, 2021
- Messages
- 2,409
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
I know, a really generic question so I will narrow it down. I am using a power steering cylinder and valve combo made as an add on for a YM2310 Yanmar tractor to add power steering to my YM2310 tractor. I will most likely be using a power steering pump instead of the tractor hydraulics because I want to keep them separate.
I think the power steering valve on the cylinder must be the open center type, otherwise a pressure limiting valve would always be forced open when the power steering cylinder is stationary but not at the travel limits.
From what I have read the power steering cylinder I bought new from a reputable dealer has a pressure limit of 1800 PSI. The dealer provided no documentation and has not responded to my emails so I don't know for sure. If 1800 PSI is the limit and the pump I buy is able to provide more I guess I will need to buy some sort of valve that bypasses higher pressure oil to the low side plumbing that goes to the oil reservoir. I guess I better get a gauge too.
So I am asking if my descriptions above are correct and suggestions regarding which bypass valve I should buy and where to buy.
Thanks,
Eric
Thanks,
Eric
