How does an air inlet temperature sensor function?
   / How does an air inlet temperature sensor function? #11
it could be the "hot wire" type of sensor, where the "hot wire" is in the airflow, and it's resistance changes with temperature(hotter temperatures increase the resistance, and colder temperatures decrease the resistance). it's usually a nichrome wire.. I've seen these go bad on cars and trucks before.. also, you need to see if it's an ECM problem!..
Ditto also.
There should be a visible coil or wire in a port (hole). On automobiles, I've cleaned similar sensors with brake cleaner on a Q-tip. Most times it works. The sensors get dirty even behind an air cleaner because they use a heated wire process. Be gentile cleaning. The wire can be brittle.
   / How does an air inlet temperature sensor function? #12
The "hot wire" sensors you folks are describing are not air temp sensors, they are mass airflow sensors - measuring amount of air taken in. Automotive applications have a separate air temp sensor which is a thermistor type and a lot of times it is incorporated into the same unit as a MAF sensor to read ambient temp. The thermistor will drop that 5 v reference voltage according to temp and are usually extremely sensitive. Anything else that changes the voltage the computer reads on that circuit can affect that reading. Automotive uses that 5 v ref on throttle position sensors, egr position sensors, coolant temp sensors etc. and any problems in those circuits can have an effect to the computer. Throwing parts at it is the typical inexperienced approach, proper diagnosis is the right way. With automotive I would use my scanner to actually read the temp/voltage the computer is seeing, see if the 5 v ref voltage is correct and all the other pertinent info is correct. I might use my dvom to confirm voltage readings at the proper pins at the computer and then trace back towards the individual components to see where a problem might be in the wiring, connectors or component.
   / How does an air inlet temperature sensor function? #13
The OP said the software he would need is 5k. Hauling it there and back and paying to have it fixed is probably going to cost a lot more than the sensor. I agree throwing parts at it isn’t the best choice but my point is it might be the cheapest.
I appreciate the responses.
I am still bugged by the fact that the problem has repeatedly gone away on a power/key cycle. I do not understand how a bad wire or bad sensor could be "fixed" albeit temporarily by what is affectedly a reboot unless it is the ECM. But if it was the ECM I would think I would see other issues and codes would be thrown.
Yesterday I fought with it for about 30 minutes in which it did not reset with the power cycle and seemed to be a hard fail. Probably at least 8-10 times the power cycle had no effect. Decided that I finally had a hard fail and maybe I could finally get somewhere. After sitting for 5-10 minutes I would power up and the inlet sensor saw 150 degrees (way higher than normal for sitting that long) As the engine started the temperature in idle started to drop rapidly to 100-105 degrees. Definitely a reverse reading and I decided in that permanent fail mode I would pull the sensor and take it home and run some test with a multi-meter. Being in the field I started it to move closer to the road and the work truck. It started fine and worked normally for the next 3 hours without any oddities. Heavy rain forecast for the next several days so I decided not to pull the sensor as I did not have any good method of sealing the open port with me in the truck so will wait to pull the sensor.
I agree with Dave right now. I am leaning to throwing a new sensor at it with all the factors of distance and s/w costs that are involved. I am starting to debate on purchasing the test equipment/software as it may pay for itself in lost time at this point.
Just hoping that it is not the ECM.
   / How does an air inlet temperature sensor function? #15
I致e been away from calibration for almost 12 years, but here痴 a little input.
First, Diesel engine痴 always run lean. The governor controls fuel injector pulse width so intake manifold temperature has nothing to do with air /fuel ratio. It痴 simply commanded fuel delivery and turbo boost level , which is a function of fuel delivered, wastegate position, and engine speed. Temperature is also used to increase pulse width, or modify pilot injection profiles for cold start, until the governor take over that function.
One thing the ambient air temperature sensor may be compensating for is the injection timing requirements at low temperatures, ie cold starting and cleanup conditions call for advancing timing to compensate for increased ignition delay at cold conditions. Most calibrations use engine oil temperature, though, or even coolant temperature, as diesel combustion tracks better to those than air temperature during operation.
Not sure if Perkins uses ambient air readings for egr control, but they may have a strategy to modify egr control valve pulse width at extremely low temperatures, so a faulty sensor could impact that.
Best bet is to monitor sensor voltage in operation to verify that there is, in fact a voltage change that corresponds to the drop in gauge reading.
As to the cost of scanners and software from Perkins, there are generic scanners out there for the heavy duty market. They are still not cheap, and won稚 do everything the factory scanner does, but a good one can be found for $300-1200.
   / How does an air inlet temperature sensor function? #16
Does the machine have an OBD2 port? I've diagnosed similar issues that did not throw codes using an OBD2 reader set to display the values from the sensor in question and monitoring the outputs. A generic reader may be able to read the sensors values as you operate the machine.
OBD2 port : no
J1939 port to read with proprietary software and hardware :Yes
   / How does an air inlet temperature sensor function? #18
If the sensor is a thermistor (they are popular for automotive applications and they are cheap) there is a self heat phenomena that may be causing your problem. This means there is some failure in that circuit that causes the thermistor to self heat or there is an unwanted resistance somewhere. Thermistors are typically easy to check with a quality VOM. Many thermistors are in the 1K Ohm to 100K Ohm range and zero power resistance is often are rated at 25C. We used thousands of them and did a quick QC check with a VOM at room temperature. Ours were from Betatherm. Their Curves are on the internet.
CASE CX57C EXCAVATOR (A52707)
CASE CX57C...
2020 CATERPILLAR 239D3 SKID STEER (A52707)
2020 CATERPILLAR...
2015 Ford Fusion Sedan (A55853)
2015 Ford Fusion...
Butterfly Artwork (A55758)
Butterfly Artwork...
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
