Front-End Loader How does a FEL rate for grading a driveway?
   / How does a FEL rate for grading a driveway? #51
Funny you mention the ratchet rake. I've been eyeballing them for clearing up the woods here at the compound. For $300, I might see if I can round up some HD angle iron and have another welding project. :)
Somebody else built something similar. Keep in mind, the steel is pretty thick. Maybe 1/2 ".
   / How does a FEL rate for grading a driveway? #52
Yeah, driveway is 1/3 mile long. I had a dozer in here a year ago to get it angled so water runs off into a ditch along the side of the mountain. I've had a few loads of (base) gravel spread on it since but now we are getting a bit of a crown between the tracks and water runs down the tracks. I welded up a 4' x 4' drag with steel tubing and rebar and I can put two 25lb weight plates on it and pull it behind my ATV. It helps, but I really can't direct the gravel very well. My Pop has a small Kubota that came with a 4' blade that he's rarely used. I think it's a 3 point setup, so it may be compatible with whatever I ultimately buy. I don't have a lot of room here and no outbuilding, so I'm trying to avoid ending up with a collection of implements sitting behind my house that I may only use once a year. I think my local Kubota dealer has a lot of stuff I could rent. Thanks!
There should be no specific tire tracks in a driveway. The driveway should be wide enuf that you can get a wheel to run anywhere on it you choose. That way the driveway can be 99% maintained by driving on it intelligently. A FEL and a field drag can easily handle the 1%.
larry
Agreed! But I have to deal with what the developer left me and certain geographic limitations. It's tight in some spots.
   / How does a FEL rate for grading a driveway? #54
It may just be me but a FEL sucks for road grading. :D
Actually, I did a pretty good job on it a couple weeks ago with the borrowed rear blade and a rented landscape rake. It shaped it up and rearranged the stones pretty well. :thumbsup:
   / How does a FEL rate for grading a driveway? #56
The fact of the matter is to do a good grading job your 4 wheels need to drive on a flat surface otherwise you will have all kinds of 'ups and downs'.
That being said, driving backwards while grading (small cuts) is better than pulling a back blade.
Foreward with bucket using the heel also is efficient but wears out the bucked heel. I added a re-enforcement wear strip on my bucket heel just for grading and it works well.
A friend welded a HD 3 x 3" angle to his bucket and that is really efficient.
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
1999 Kubota L2500D Utility Loader Tractor (A55851)
1999 Kubota L2500D...
2017 FORD F550 XL SERVICE TRUCK (A57192)
2017 FORD F550 XL...
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
2022 Haybuster H1135 Tub Grinder (A55314)
2022 Haybuster...
