How do you wash your tractor??
   / How do you wash your tractor?? #12
Well,will admit washing a tractor makes more sense than washing a chicken,but still...
   / How do you wash your tractor?? #13
We pressure wash our tractors once a year when we line all 11 up side by side at our big party in the fall. Other than that, we just hose them off every now and then when they get REALLY dirty.
Kyle
   / How do you wash your tractor?? #14
You say "Honey that tractor really Needs washing".
Bake
   / How do you wash your tractor?? #15
Definitely shouldn't use a pressure washer on a chicken. I take mine to the car wash.:D:D
   / How do you wash your tractor?? #16
I pressure wash using rainbarrel water.
the head of the rain barrel (45 gallon) is typically about 3 or 4 feet above the powerwasher. The powerwasher is one of those typical electric ones that cost $150.
I do make sure to use a screen in the garden hose (same type screen that is used in a washing machine hose.)
to prevent floating debris from rainbarrel getting into hose.
But I also cover top opening of rainbarrel with bugscreen so actually very little debris gets "rained" into barrel.
I have no probelm with pressure, the unit bumps up the pressure to sufficent amount to wash mud off the tractor once a month. I wash my truck that way too ! Better than using well water !
jake
   / How do you wash your tractor?? #17
Around here people would think you were a bit touched if they saw you washing your tractor.
   / How do you wash your tractor?? #18
Pressure washer..... Been doing it for 38 years in the case of one particular tractor. I will not work on dirty equipment. Makes no sense. If pressure washing hurts them, I'd suspect it would have in 38 years. No reason for me to believe that's happening. Of course, it does take a little bit of common sense. Don't spray directly into electrical components, don't point blank into seals and bearings, and use a wide angle nozzle and NOT a pinpoint jet.
   / How do you wash your tractor?? #19
Common sense? :eek: Isn't there some kind of law against using common sense?
   / How do you wash your tractor?? #20
Oh, the comments I could make on that.......:eek: If in fact it IS a law, I'm quite certain it's been enacted in the last 4 weeks.
Now I'd better be quiet a'fore this'n goes all political!
1986 Nissan King Cab Pickup (A52384)
1986 Nissan King...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
1996 FORD F SERIES DUMP TRUCK (A51406)
1996 FORD F SERIES...
Hydrema 912HM Haul Truck (A52384)
Hydrema 912HM Haul...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
