How do you use a landplane
   / How do you use a landplane #1
4x4moses
Laurel, MS
Kioti DK4510
I have a long gravel driveway, and frequently use my son-in-law's Land Pride landplane. Working with it recently, I tried three different positions, but didn't see a lot of difference in the result. How do you use your landplane; front tilted slightly down, front slightly tilted up, or as flat as possible? I've always heard that flat is best; but having the front tilted slightly up (about 1-2 inches) seems to put less strain on the implement.
   / How do you use a landplane #3
I run mine flat also. Flat while it is working. When you start to pull the front blade will want to dig in and it may cause the back end to lift slightly so lengthen the top link a little so that the runners are flat while cutting.
gg
   / How do you use a landplane #4
I let mine lay flat and float. About the only adjustment I'll is to raise one side to create more of a crown in the driveway, then I still drop it to be flat but don't really allow it to float.
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
2016 John Deere 5055E 55HP Utility Tractor (A55973)
2016 John Deere...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
