how do you transfer the 5g hydr oil to your tractor?
   / how do you transfer the 5g hydr oil to your tractor? #1
sacsr
Kinston, NC
Yanmar 187D Terramite T5C Bush Hog D4-10
What is the best and lowest cost way to transfer from the bucket?
   / how do you transfer the 5g hydr oil to your tractor? #3
A funnel and a steady hand. Ken Sweet
   / how do you transfer the 5g hydr oil to your tractor? #4
depends.
5 gallon buckets for a couple spots on the tractors are just way to big. so i end up buying a smaller size container. use it up, and then pour from 5 gallon bucket into it.
i also have a few different types of funnels. though i tend to use a larger funnel that has a cheap spout on it, that simply unscrews when i don't need it.
i have been looking for a funnel that just screws into the hole in 5 gallon bucket and pour that way. and funnel i am looking for also has a built in breather.
i haven't yet, but once it warms up enough, i might use a little drill pump to change 21 plus gallons in the 555c. simple little plastic pump that ya hook to end of drill. and attach some hoses to it. i think i paid like 7 bucks for it. but i don't remember were i bought it, just know it was rated for oil. and it was like oh ya this will come in handy.
   / how do you transfer the 5g hydr oil to your tractor? #5
I use a large lever-operated barrel pump, the kind that replaces the
top of a 5-gallon container. It is a little tedious when doing a dry fill,
but it sure beats the funnel method. They are especially nice for
topping up hyd oil as there is no mess, and I stick the filler hose back
into the bucket top when done.
You can get these at HF Tools or Northern.
   / how do you transfer the 5g hydr oil to your tractor? #6
Me too!!!!!!!!!!!!!!!:thumbsup:
Have one for gear lube also.
   / how do you transfer the 5g hydr oil to your tractor? #7
In my experience, and this goes for EVERYTHING:
NOTHING is both the best AND lowest cost at the same time.
I personally just use a funnel as others have mentioned. Since I am only doing it ~once a year, I caon put up with it. If I was doing it everyday, I'd probabally use a hand pump. And if you look, you can probabally find an electric pump that will work as well.
   / how do you transfer the 5g hydr oil to your tractor? #8
Would a 1/2" hose and siphon work? I could sit the 5 gal on the fender and start a siphon.
   / how do you transfer the 5g hydr oil to your tractor? #9
like the first reply said. cheapest way? a big funnel.. and you holding the bucket.
it's what I do... :)
soundguy
   / how do you transfer the 5g hydr oil to your tractor? #10
I just set the funnel over the hole and pour in with the bucket. There are a lot of other more complicated ways, I like to keep it simple though. :)
Carnival Ticket Booth (A51691)
Carnival Ticket...
UNUSED RETRACTABLE GARDEN HOSE REEL (A54757)
UNUSED RETRACTABLE...
UNUSED LANDHONOR SD-22-72W NO TILL SEED DRILL (A54757)
UNUSED LANDHONOR...
2003 FREIGHTLINER BUSINESS CLASS M2 SPREADER TRUCK (A54756)
2003 FREIGHTLINER...
2013 John Deere 350G LC Hydraulic Excavator (A53421)
2013 John Deere...
2013 freightliner Altec D2050-TR Derrick Digger Truck (A52377)
2013 freightliner...
