how do you transfer the 5g hydr oil to your tractor?
   / how do you transfer the 5g hydr oil to your tractor? #1
sacsr
Kinston, NC
Yanmar 187D Terramite T5C Bush Hog D4-10
What is the best and lowest cost way to transfer from the bucket?
   / how do you transfer the 5g hydr oil to your tractor? #3
A funnel and a steady hand. Ken Sweet
   / how do you transfer the 5g hydr oil to your tractor? #4
depends.
5 gallon buckets for a couple spots on the tractors are just way to big. so i end up buying a smaller size container. use it up, and then pour from 5 gallon bucket into it.
i also have a few different types of funnels. though i tend to use a larger funnel that has a cheap spout on it, that simply unscrews when i don't need it.
i have been looking for a funnel that just screws into the hole in 5 gallon bucket and pour that way. and funnel i am looking for also has a built in breather.
i haven't yet, but once it warms up enough, i might use a little drill pump to change 21 plus gallons in the 555c. simple little plastic pump that ya hook to end of drill. and attach some hoses to it. i think i paid like 7 bucks for it. but i don't remember were i bought it, just know it was rated for oil. and it was like oh ya this will come in handy.
   / how do you transfer the 5g hydr oil to your tractor? #5
I use a large lever-operated barrel pump, the kind that replaces the
top of a 5-gallon container. It is a little tedious when doing a dry fill,
but it sure beats the funnel method. They are especially nice for
topping up hyd oil as there is no mess, and I stick the filler hose back
into the bucket top when done.
You can get these at HF Tools or Northern.
   / how do you transfer the 5g hydr oil to your tractor? #6
Me too!!!!!!!!!!!!!!!:thumbsup:
Have one for gear lube also.
   / how do you transfer the 5g hydr oil to your tractor? #7
In my experience, and this goes for EVERYTHING:
NOTHING is both the best AND lowest cost at the same time.
I personally just use a funnel as others have mentioned. Since I am only doing it ~once a year, I caon put up with it. If I was doing it everyday, I'd probabally use a hand pump. And if you look, you can probabally find an electric pump that will work as well.
   / how do you transfer the 5g hydr oil to your tractor? #8
Would a 1/2" hose and siphon work? I could sit the 5 gal on the fender and start a siphon.
   / how do you transfer the 5g hydr oil to your tractor? #9
like the first reply said. cheapest way? a big funnel.. and you holding the bucket.
it's what I do... :)
soundguy
   / how do you transfer the 5g hydr oil to your tractor? #10
I just set the funnel over the hole and pour in with the bucket. There are a lot of other more complicated ways, I like to keep it simple though. :)
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
