Oil & Fuel How do you service the hydraulics on a L2500 4WD Kubota w/FEL (1st timer)
   / How do you service the hydraulics on a L2500 4WD Kubota w/FEL (1st timer) #1
brothercooter
Jonesboro, Louisiana
Kubota L2500
I recently purchased a L2500 4WD with a L400 FEL not knowing the history of the tractor (713 hours) I want to change the hydraulic fluid and service it but don't know the first thing about it please help
   / How do you service the hydraulics on a L2500 4WD Kubota w/FEL (1st timer) #2
Messicks, 877-260-3528, sells manuals.
   / How do you service the hydraulics on a L2500 4WD Kubota w/FEL (1st timer) #4
Some may not agree but I use Wix filters whenever possible In my opinion they are as good and much cheaper than OEM Kubota. You can go to wixfilters,com and look up either by number interchange or make.
   / How do you service the hydraulics on a L2500 4WD Kubota w/FEL (1st timer) #5
I think you will find that the "filter" is a reusable/replaceable screen;at least it is on our L3000DT.Messicks is a great source of info and parts.You will have to go to www.kubotausa.com to get part numbers and then purchase from Messicks or your local dealer.
   / How do you service the hydraulics on a L2500 4WD Kubota w/FEL (1st timer) #6
Or you can just call Messicks, they have always been good with me, even suggesting a less costly alternative to one part I was ordering. Also their delivery has always been QUICK.
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A56858)
2008 Ford F-550...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
Butterfly Artwork (A55758)
Butterfly Artwork...
2000 Sterling L9513 Winch Truck (A55315)
2000 Sterling...
