how do you remove this?
/ how do you remove this? #1
forgeblast
Elite Member
nicholson, pa
John Deer 318
Hi all i have an ariens 932 snow thrower with a 7 hp techumseh motor.
the motors dead, i want to replace it but i cannot get the main drive pully (sheave) off. i have taken the pins out (two) and the square key, i have wd'ed and it still will not budge. is there a "trick" to it?
thank you for your help.
Forgeblast
/ how do you remove this? #2
Probably need a pulley puller. Thing with three claws that fit under the pulley and a threaded rod in the middle that presses on the shaft. You tighten the rod with a wrench and the pulley pops off, rather loudly too.
/ how do you remove this? #3
Apply heat, lots of it. That will often do the trick. Worst case, you will need the puller AND heat. :)
Wear eye protection when using the puller. I had an India made Harbor Freight puller turn into a grenade. I ended up buying an expensive US made puller.
thats for the info reguarding HF's puller. where can you find better pullers. autopart stores? or HD or Lowes? Thanks again i appreciate it.
Forgeblast
/ how do you remove this? #5
I know Checker Auto around here will rent you a puller for cheap. Your local parts store may do the same. I think I paid $5 for a day to rent a puller to take my motorcycle engine apart.
/ how do you remove this? #6
If you have an autozone nearby AutoZone.com - Get in the Zone! they still have (I'm 99% certain) a tool rental program. Here's how it works: you buy the pulley puller from them and, when you're done, return it for a credit. Seriously. This is the way that their program works.
Richard
/ how do you remove this? #7
Richard
A full credit???
At Checker you buy the tool and then get most of the money back when you return it. It still ends up costing you a little bit.
/ how do you remove this? #8
Iplayfarmer said:
A full credit???
AutoZone gives you full credit on return, but I think their intent is to loan you tools to use when installing parts purchased from them. I don't know how they'd feel about just lending a tool. If you buy from them often, they might go for it. Can't hurt to ask.
/ how do you remove this? #9
I use the loaner tool program at Autozone quite a bit. It works just as described- you pay up front the full price for the tool, and you get all your money back when you return it- even the sales tax. So when you return it, it costs you nothing. They have a good selection of specialized tools.
-Fordlords-
/ how do you remove this? #10
-Fordlords-
That's it! I've got to find an Autozone!
I may have to drive a bit.
wow thats an awesome deal. I have a guy who does a lot of haying looking for his puller, but he cant find it and its driving him crazy. so i may have to do the autozone route. thank you all that was great info.
forgeblast
/ how do you remove this? #12
O'Reilleys does the same thing. You basically pay a deposit of the full price of the tool and get it back when you return it. In fact, I did just that to get use of a very nice combo 2/3 arm puller set to work on the steering gear of my Kubota L210. I told the guys at O'Reilley's up front that I was working on a tractor and wasn't going to be buying parts for it from them! They didn't care, and because of that they've gotten a fair amount of business from me where I did buy stuff from them.
Chuck
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
2019 Nissan Rogue AWD SUV (A64557)
2019 Nissan Rogue...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
