How do you remove the joy stick from the housing on a JD 5300?
   / How do you remove the joy stick from the housing on a JD 5300? #1
unifi
Madison, NC
JD 5300
I have a JD5300 and housing on the Joystick has broken so I ordered a new one for JD but I can't figure out how to get the joystick off so I can replace the old housing. Any help will be appreciated.
Unifi
   / How do you remove the joy stick from the housing on a JD 5300? #2
Welcome to the forum.
According to the tech manual
early models
1 remove right wheel & fender
2 remove right hand control console
3 remove shield (P) the broken part?
4 lift boot to access square hole. use suitable tool to push rod B) to relieve tension on E-clip. Remove e-clip
later models
3 remove shields c&l
   / How do you remove the joy stick from the housing on a JD 5300? #3
I looked at my machine. Depending on your wheel clearance, you may be able to remove the right fender without removing the wheel. Looks like Removing the right fender is required to access the screws holding the housing together.
2021 Dosko 337S-13HC Walk-Behind Stump Grinder (A49461)
2021 Dosko...
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
