How do you read your dipstick?
/ How do you read your dipstick? #21
Most TLB op manuals I have read say to check the oil level with the BH in transport position. I suppose in this position about half the cylinders are extended and half retracted, so it gives a good "average" oil level.
/ How do you read your dipstick? #22
I checked the hydraulic fluid level today in full sunlight and it was easy to see where the stick was wet. It did not work well at 5:30 PM last time.
That's one reason why I keep a flashlight in the tractor garage. It is easy to see if you have enough light.
Let's take it one step further. I know the loader is supposed to be on the ground when checking the fluid level, which leads me to believe that all cylinders should be closed. So when checking the hydraulic fluid with a BH should the dipper stick and bucket be fully raised, thus closing the cylinders? (the boom and outriggers would already be closed)
The B21 manual shows how the backhoe should be positioned when checking the hydraulic fluid level. I would agree that it is a transport position with the backhoe up against the back of the tractor.
/ How do you read your dipstick? #24
I have read through the manual for the BH and don't recall this being discussed. I will have to re-read it I guess. Thanks for the imput.
/ How do you read your dipstick? #28
I am extremely relieved to learn I'm not getting blind. Never had any problem reading the dipsticks on my previous tractors, but the yellow plastic things on the Deere are a real PITA.
