How do you protect your PTO shaft when it's not being used?
   / How do you protect your PTO shaft when it's not being used?
Not for these people, it has to be polished, lubed, covered & kept in a climate controlled building with a cement floor.
It needs to be insured and alarms on the tractor & building.
Good point. It was a lot easier with my old tractor, when it was dry and rusty so that I had to use vise grips and my two lb hammer to get the implement shafts on and off.
   / How do you protect your PTO shaft when it's not being used? #52
I usually remove whatever implement Ive been using when Im done with it. But if you used the same one for a long time I could see some corrosion setting up.
I would use a wax based chain lube like I use on other pivot areas on my three point. It doesnt attract dirt or debris.
I apologize for the serious text. Hopefully we will now return to our jovial comments. 😁
2021 JOHN DEERE 325G SKID STEER (A52707)
2021 JOHN DEERE...
UNUSED FUTURE CLG72 72" HYD CURVED LOG GRABBER (A57193)
UNUSED FUTURE...
WOLVERINE TF-4-66-5500 G PIN ON PALLET FORKS (A57192)
WOLVERINE...
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 68in Dual...
2007 Nissan Frontier Crew Cab Pickup Truck (A55852)
2007 Nissan...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A53422)
2007 Ford F-150...
