How do you plumb auxilary hydraulic hookups to the rear of a ford 1715
   / How do you plumb auxilary hydraulic hookups to the rear of a ford 1715 #1
TJ4ker
ford 1715
I want to put rear hydraulic connectors on the rear of my ford tractor.
I think the best way to do it on a ford is to split off the inlet side of the hydraulic manifold block and make a loop in the system.
Thoughts?
Terry
   / How do you plumb auxilary hydraulic hookups to the rear of a ford 1715 #2
The best way is to buy the kit from New Holland: SBA340002301 (see attachment)
   / How do you plumb auxilary hydraulic hookups to the rear of a ford 1715 #3
That do you want to do with it run a logspliter or something else. E-mail me at dalepratt@netacs.net If you get the kit will cost you a lot of money. Can show you how. to do both the cheap way. I have a 1715 also.
   / How do you plumb auxilary hydraulic hookups to the rear of a ford 1715 #4
take the two plugs out of the hyd manifold on the right hand side and put a spool valve on the fender and hook up some lines to go in between and turn the flat head screw on the manifold 90 degrees and go use it will work just put one on a 1320
2018 John Deere 8400R MFWD Tractor (A53342)
2018 John Deere...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
Adams 5T HC Spreader (A53472)
Adams 5T HC...
UNUSED CHERY INDUSTRIAL 10' - 15 DRAWER WORKBENCH (A51248)
UNUSED CHERY...
LMC LOT NUMBER 140 (A53084)
LMC LOT NUMBER 140...
