How Do You Monitor Generator Output?
   / How Do You Monitor Generator Output? #1
bdhsfz6
Elite Member
Northeastern Pennsylvania
Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
During a power outage, I'm always concerned about overloading the generator. The one I have is 11KW and it will handle most of what I need but there are times when I'd like to know the actual amp draw I'm using.
There are several products on the market that let you do this with a smartphone. These for example, seem like a good way to do it:
Has anyone tried these products, and if so, how well do they work?
I also considered installing a simple ammeter on the generator and monitoring it with a security camera. That way, I could check the load via my home security camera system.
I suppose the best approach is to get a generator big enough to handle every appliance I own, but that isn't an option for me.
Do you monitor your generator output, and if so, how do you do it?
   / How Do You Monitor Generator Output? #3
On my 10kw diesel generator, I installed 3 of those cheap volt/amp/HZ meters. One per phase. Might not be exactly what you need though. They also flicker a little bit when recording a video of those, but still perfectly readable.
   / How Do You Monitor Generator Output? #4
Emporia Vue 3 Home energy monitor. Just get the "Monitor Only" version for $99. Clamps on the mains and monitors real time energy usage. Smartphone app.
   / How Do You Monitor Generator Output? #5
You’ll want two amp meters, one for each hot leg, if you want to know actual amps, assuming you have some 120v loads.
I have a pretty good feel of the voltage and frequency drop vs amp load for my portable 5k generator.
I just occasionally check an outlet with my DVM when I hear it working hard. Most $25 multimeters will read Hz on AC as well as the voltage. I know from actual clamp on current measurements previously made, about what the load must be.
You’re probably looking for something more exact though
I looked at this product on Amazon but was unable to find it's operable temp range. I need to put it in an unheated barn.
The link you provided gave me that info. Thanks!
   / How Do You Monitor Generator Output? #7
i use Genmon on my generac whole house.
and for the shop, i use a set of chepo meters on the manual start switch.
   / How Do You Monitor Generator Output? #8
I built my own panel with amps, Hz, volts for both A phase and B phase, street and gen power. It's nice, because I know when street power comes back on.
   / How Do You Monitor Generator Output? #9
You will need a good WIFI connection in the barn.
I added a WiFi extender for other devices I use in the barn. It provides a good strong signal.
2011 International WorkStar 7400 Truck, VIN # 1HTWGAAR8BJ325794 (A48836)
2011 International...
New/Unused 7ft 20 Drawer Work Bench (A48837)
New/Unused 7ft 20...
2021 CATERPILLAR 305E2 EXCAVATOR (A50458)
2021 CATERPILLAR...
2011 RAM 5500 HD ARMORED TRUCK (A50505)
2011 RAM 5500 HD...
New/Unused Self Dumping Hopper (A48837)
New/Unused Self...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
