How do you manage your attachments off the tractor?
   / How do you manage your attachments off the tractor? #11
I have all mine configured to my quick hitch. Everything sits outside on concrete blocks. No pushing or pulling.
   / How do you manage your attachments off the tractor? #12
My implements are on pallets so I can move them with my QA forks. I keep the bucket and back blade on the tractor and keep 2x4's on the ground to rest them on so they don't rest directly on the dirt.
   / How do you manage your attachments off the tractor? #13
I have 3 QA buckets, a box blade, a rake, a chipper, a carry all,forks and probably something else I'm forgetting.. the chipper is covered and stored under a deck out of the weather. The others are scattered behind the shed/barn.. lately it has been bothering me as it starts to look like Sanford and Son around here. I'm thinking about getting some commercial racking like you see in Home Depot or lowes and using them to stack all the attachments on. ..behind the shed/barn out of sight.
I been thinking about the same thing and I like the idea
   / How do you manage your attachments off the tractor? #14
My stuff is all indoors so far. My rear blade has 2 car dollies under the blade and a transmission jack under the frame so it stays at mounting height and wheels around. My loader sets on 2 wood dollies from Harbor Freight and wheels around. My backhoe sits on the floor and stays wherever I park it. I just put a set of jack stands under it to keep it from squatting. The MM mower has it's own castors to move around on.
   / How do you manage your attachments off the tractor? #15
Same here.
Two tractors + TLB, 20' equipment trailer, 5' tiller, 5' cultivator, 5' bush hog, 2 bottom plow, 2 sets forks, box blade, 3 rear blades, boom pole, all stored inside, on concrete floor. Most implements on HF dollies.
   / How do you manage your attachments off the tractor? #16
I use dollies for the 3 PH attachments. Makes it easy to both stage them and connect them.
Just got a SSQA equipped loader so will try dollies on FEL stuff too but not sure they will work yet....but thinking they will make alignment easy.
   / How do you manage your attachments off the tractor? #17
I park so that reconnecting can be achieved with a minimum of effort since I work alone.
The post hole digger is the epitome of a PIA implement for a single person to mount. To solve that problem I have a 6" auger, really useless for hole drilling, screwed in the ground to a height of about 18". I keep my augers off the digger and store the digger with the drive shaft stuck in this auger. Works really good.
   / How do you manage your attachments off the tractor? #18
Dollies on a concrete floor is the best way to cheat. I suppose that if you could pack down crusher-run gravel and make dollies with larger pneumatic tires, that might be a possible solution. The only other suggestion would be to make custom pallets that are installed level, and do something to allow implements to be shifted around on the pallet (maybe oil the wood or use a slippery material on top like polyethylene). The key to me is allowing the implement to move and rotate side to side and front to back as you align and pin it to the 3-pt arms.
I'm thinking of making a large saw horse, maybe 5 or 6 feet high and 6 or 8 feet long, and hanging two or three implements from it. When they're hanging, they are much more free to move around a small distance.
   / How do you manage your attachments off the tractor? #20
I have a 22' trailer I set a lot of my stuff on when not in use. Currently I have my box blade, loader bucket, brush hog, finish mower, and pallet forks on it. The tractor, backhoe, tiller, auger, and grapple all are inside the barn. Ploughs (disc, chisel, middlebuster) are all on slabs out behind the barn.
I did learn that a finish mower rolls especially easy on smooth surfaces like a trailer deck. I now backup to a pallet and set the finish mower off on the pallet so when it goes on the trailer, it stays there...
2014 Ford Fusion SE Sedan (A55758)
2014 Ford Fusion...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2015 Chevrolet Silverado 3500HD Knapheide Enclosed Service Truck (A56858)
2015 Chevrolet...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
