How do you lift the Ventrac 4500 Tough Cut Mower deck?
   / How do you lift the Ventrac 4500 Tough Cut Mower deck? #21
After looking at video, can you not attach a hook, or drill a hole, in the most forward point
on the ROPS, over the operators head? Then get something similar to this to pull from
ROPS to one of the front wheels on the deck...
12 Lb. Capacity Cable Puller
Assuming you had the headroom, you could even permanently mount a small boat trailer winch
( think jet ski size) on it
   / How do you lift the Ventrac 4500 Tough Cut Mower deck? #22
Chris Lowe said; "PRS - Thanks for the sharpening and balancing equipment recommendations. I wonder if your mower deck configuration is different from mine. Here is mine in the flipped-up position with the hydraulics lifting the deck as far as possible . The gap under the back edge of the deck is less than 3/16" (and the rear rubber skirt is folded forward under the deck on the other side of that gap). I suspect that something would get damaged if I did this on a nearby slope then tried to drive in either direction back to the shop, it is "plumb" (vertical). Mine is set to cut at 5" and will move without dragging hard parts. After today's work, I probably need to lift and sharpen again, lots of rock outcrops on steep banks.
prs
   / How do you lift the Ventrac 4500 Tough Cut Mower deck? #23
Use a ratchet strap strapped backed to the ROPS.. hook to the dual wheel and do one side, put a ratchet on the other and take your time, it will get up to that easy break point and push it over, then I lock the strap in for safety... along with the pins..
   / How do you lift the Ventrac 4500 Tough Cut Mower deck? #24
I have a homemade set of ramps I drive up them with the deck fully raised and do what I have to do I use a ratchet strap to the light guard on my rops to hold it up .... I power wash the under side like that too
   / How do you lift the Ventrac 4500 Tough Cut Mower deck? #25
I use a hoist in my shed. Works great. I don’t lift all the way up. I think I could but just being safe
   / How do you lift the Ventrac 4500 Tough Cut Mower deck? #26
The way I made it easy to lift, a 4’ 2x4 and piece of rope. Lay the 2x4 over the handle on the front and put the rope over the 2x4 and under the handle on each side then back up on top and tie a knot, then slide the 2x4 back to the flat on the mower. If you need more use a 6’ footer…. Jim
   / How do you lift the Ventrac 4500 Tough Cut Mower deck? #27
If I could take a slight detour…on the Steiner rough cut, is it necessary to loosen/remove belts to lift the mower? Anyone have the steps they use for that mower?
   / How do you lift the Ventrac 4500 Tough Cut Mower deck? #28
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
