How do you leave your tractor's hydraulics at the end of a day?
   / How do you leave your tractor's hydraulics at the end of a day? #11
Loader and three-point lowered when off.
Another good reason to lower the three-point (if you have an attachment on it) is because if you have position control and it has leaked down, the implement will suddenly raise when you start the machine and scare the puddin out of you...
   / How do you leave your tractor's hydraulics at the end of a day? #12
I lower mine. I sometimes see a backhoe bucket or hay spear or something and it's way up in the air. Machine is off and not a sole around. Cleary they parked it that way.
Drives me nuts seeing that.
Years ago, I was cleaning up some stuff on backside of farm. Place had been timbered (so I was cleaning up a lot of the crap laying on the ground)
Backed over essentially a branch. Might have been 6-10 inches diameter.... rear tire hit the end of it.....the other end rose and speared the hose holding the backhoe up.
That hoe dropped "right now". I presumed if the hose ever failed, the hoe (or loader) would bleed down.....that is NOT how this one went. It dropped scary fast. I gained new appreciation for how cautious (scared?) I am around these things and glad I tend to be OCD about being aware of as much as I can be.....
I see these implements raised in the air and just see a potential death trap.
   / How do you leave your tractor's hydraulics at the end of a day? #13
I always lower everything, but I sometimes go by construction sites and I see equipment like air compressors raised up on cranes, excavators or cherry pickers. I assume it's to discourage theft, but I always wonder about safety/liability in those cases.
   / How do you leave your tractor's hydraulics at the end of a day? #14
The backhoe should have a lock pin on it...Engage before moving the machine to reduce stress. Backhoes are typically set with the bucket on the ground and outriggers down when not in use.
   / How do you leave your tractor's hydraulics at the end of a day? #16
My reason has nothing to do with loads. It’s my shins.
After walking into the FEL and screaming out creative four letter words, I now remember to lower it completely to the ground.
   / How do you leave your tractor's hydraulics at the end of a day? #17
I leave the outriggers up (both on and off the tractor) but secure them with tie-downs because they will leak down in about 5 minutes if I don't.
   / How do you leave your tractor's hydraulics at the end of a day? #18
Bucket down and curled to minimize rod exposure, unless there’s snow and ice to melt, then I leave bucket leading edge down resting on a 2x4 to melt out and drip in the garage
Control in float position.
3PH lowered if there’s an attachment. Leaving it raised with an attachment, loads the starter motor and engine, before there’s good oil pressure.
Pressure relief in hydraulics is marginally better than leaving loaded, but is better, so worth it
   / How do you leave your tractor's hydraulics at the end of a day? #19
Yep, should..... but doesn't. When I got the machine 20 years ago, the "flipper" that drops onto the pin to hold hoe upwright, had been broken and welded back. Also, the 'brake lever' used to actuate the flipper up/down didn't work. I literally had to reach out, lift then with other hand, move hoe.... until I forgot one day and it snapped again.
Was a horrific pain in the hiney so I just pinned the flipper out of the way. That woudn't have saved my day though..... just having the machine running was pushing fluid out the hole. Had it been pinned up tight or not, machine was dead and I had to walk home.
   / How do you leave your tractor's hydraulics at the end of a day? #20
On the equipment that has to have the key on to move the hydraulics, I will leave it however it is. I left the boom truck holding stuff overnight several times.
2013 RAM 3500 FLATBED (A58214)
2013 RAM 3500...
2014 Ag Spray Schaben Sidedresser (A56435)
2014 Ag Spray...
CAT930K (A58214)
CAT930K (A58214)
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
JOHN DEERE 6615D MFWD TRACTOR (A52708)
JOHN DEERE 6615D...
Skid Steer Concrete Mixing Bucket (New/Unused) (A59225)
Skid Steer...
