How do you keep the trailer backup battery charged. (or do you)
   / How do you keep the trailer backup battery charged. (or do you)
Thanks for all the posts. I have the info I was looking for. I originally thinking that more would try solar. Not true. From the responses, it is clear to me that most who are successful use some maintaining system other that solar. Probably because of the cost, as RickB inferred - or maybe said. Ha!. I think I like the idea of having more than one and keeping them on a maintainer, and rotating them out. As for AGM, this is my first experience. Well, if the solar system fails, I probably dig out the maintainer and buy a couple lead acid. I do know if only one part of the solar fails, solar panel or controller, it will not be worth replacing due to the cost of that part. Thanks for all the input.
some of the pic's were a little small for me, sorry. Any concern of heat with the sealed pelican case?
Best,
ed
Hi Ed. Sorry about small pix. I should have made them larger. The AGM battery in the case is a 18 amp hr Motorcycle battery. The original trailer battery was a 5 amp hr. After 4 years of use, the battery seems to always be in great shape. But you make a great point, Maybe I should paint or coat that box white or any more reflective color. I thought to use AGM because even though lead acid is sealed, most that I know are still vented. I thought AGM might be safer in a closed container. I'll be sure to include larger pictures if I need to post again. Thanks, Larry
   / How do you keep the trailer backup battery charged. (or do you) #33
5 watt panel on the car hauler, 10 watt panel on the dump trailer both with a small waterproof controller in the respective battery boxes. About 5 years use on each with no problems. The tractor building has a 100 watt panel & deep cycle battery hooked to interior LED lighting & exterior LED motion lights.
   / How do you keep the trailer backup battery charged. (or do you) #34
I have used this system for 4 years. NOW THE QUESTION – I have not seen any trailer using solar. How many of you guys do something like this, and If not, how to you manage that stupid little worthless battery?
You can order it an option on many trailers new (the solar maintainer). I bought a used Diamond C gooseneck last year, put in a new battery and added both a 1.8W panel with built in maintainer ($21.99) and also a Hopkins break away battery charger ($5.89). I only haul a handful of times a year, but so far, this has kept the battery in top condition. I drilled and tapped four mounting holes in the top of the gooseneck for the panel and installed the hopkins charger in the battery box with the new battery. At roughly $30 and 30 minutes time, it was worth the time savings of not having to bring the battery in to charge regularly. I have 6 battery tenders I use on other equipment that sits in the garage/basement, but my wife would be unlikely to reinstall the battery if she needed to take the trailer somewhere and I wasn't around. (That's a fun story for another time, my 5'2" 110lb wife has no problem taking the dually with the 32' flatbed when she finds something she wants to go buy, hehe)
   / How do you keep the trailer backup battery charged. (or do you) #35
I pull the battery if it’s going to be a long time between uses. I store the battery hooked up to a battery tender, not a cheap harbor freight one, battery tender brand. Some people don’t believe they help but my batteries in my rv, motor cycles, and equipment last a lot longer.
   / How do you keep the trailer backup battery charged. (or do you) #36
I have a question, my most recent trailer came with a small Lithium Ion Battery pack. I use the trailer a couple of times a year. I admit i don't check it. In all the posts above are you talking lead batteries only or including lithium Ion which don't have the same discharge problems in general?
That is a great option. 4 years ago I did not know anyone had it. Sounds like what I wanted to do but at 10 percent of the cost. Thanks.
   / How do you keep the trailer backup battery charged. (or do you) #38
It sounds like you need a bit more than that little panel for the GPS tracker, but I do believe you could build a new solution now much less than what you built then. Either way, I like your setup.
It may not be for everyone, but personally, I wanted to ensure my battery was always present and functional. I use my flatbed mostly for hauling hay a few times a year; with an average load at 9T of hay, the overall trailer is 12.5T being towed. God forbid it ever came detached, but I try to do everything in my power to make sure all safety equipment (brakes, batteries, tie downs, tires, etc) are in full working order for a worst case scenario.
   / How do you keep the trailer backup battery charged. (or do you) #39
I'm amazed at the amount of responses to this post and the differing opinions. Batteries are like pizza, everyone has their favorite. Keeping them charged is the same, everyone has their idea of what is the most cost efficient and practical. It appears from all the posts, maybe a couple of common denominators are appearing, location (weather), frequency of use, and my favorite, "that's they way my daddy did it". I just started solar tenders this past fall for tractor, mower and trailer. So far I'm impressed. Batteries are getting closer to $100 but if they aren't charged when you need them, what's the actual cost? Good luck to all and I will now return to obscurity.
   / How do you keep the trailer backup battery charged. (or do you) #40
I have a 10W solar panel from Northern tool on my 18' flat deck equipment trailer. I installed a 12v deep cycle RV battery. The motorcycle battery that came on the trailer never stayed charged up properly even using the trailer multiple times per month. There is enough voltage drop between the tow vehicle electrical system and the trailer battery that even when everything was new, the charging voltage at the trailer battery may only be slightly above 12 volts, or maybe less. It takes 13-14 volts or more to charge 12v automotive batteries. The solar panel keeps the RV battery charged up and ready to use when I need it. I also have a 9,000 lb winch fed from the RV battery which is always ready to go. Breakaway switch is also wired to this system. The solar panel cost about 37$ from Northern. This system works great for my use. If I used the winch daily a bigger panel would be needed. Been using this system about 3 years now.
Volvo A40D Off Road Dump Truck (A56435)
Volvo A40D Off...
(2) OIL DRUMS & PUMP (A58374)
(2) OIL DRUMS &...
2005 John Deere 330CL (A55272)
2005 John Deere...
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
