How do you hook your Log tongs to draw bar?
   / How do you hook your Log tongs to draw bar? #41
I understand your point but would also note that you and 20-20 are survivors of this practice. The guys who did not survive are not posting on TBN. The fact that some people go a lifetime smoking two packs of cigarettes a day does not mean that there is no serious risk to the practice.
As I've stated earlier, I used the word "dumb" to insure that it made an impression on a new tractor user or a first time log hauler that might otherwise blindly adopt the practice without considering the risks. It is the type of practice that will eventually disappear just as driving without seatbelts will disappear as the public gets over the natural reluctance to change old habits and considers the costs/benefits of a new safer practice. That doesn't mean everyone who still does it is dumb but perhaps I would consider that term, lightly, for someone just starting out who studies the options and risks and still decides to do it. Put it this way, your mother would definitely give you a dope slap if she knew you were doing something risky when there are reasonable safer alternatives.
Island, I have been in the woods most of my life. In my former profession, I saw dumb ways and smart ways to do the same thing. In this case "dumb" means putting your or someone else's life in a precarious instant. I have had several instances where I've been compromised by the unforeseen and thankfully, have never been bit by the complacency bug Roy mentioned. Variables are key here. I have skidded logs with full size skidders. The logs are off the ground several feet. The skidder does not flip on its back for several reasons but I have seen skidders topple when a hitch became too large. My tractor has 20 hp and weighs 3000 Ibs. It has a front end loader, rear tires are loaded and it is 4 wheel drive. The largest hitch does not go above 2000Lbs. The log is several inches form the ground. The log front tip does not catch on obstructions which in this case may be a safety factor. Do not forget that the drawbar pull does not necessarily guard a tractor from flipping. I actually saw a guy get killed on a Allis 45 when show boating attempting to pull 3 large logs attached to his draw bar. He popped the clutch and over he went. I am not going to say you are incorrect in your advice especially that very few people on this forum know just who they are communicating with. As a matter of fact, you are more correct than I under that consideration. But I will state that blanket statements should not be made without knowing the variables. I survive anything like this because I'm careful and there may be many more people on this forum who are just as careful and would have much success with this method as I or 20-20 have. My tractor is not powerful enough or does not weigh enough at the rear to plant the tires so hard as to have the tractor rotate around the axle. Your tractor on the other hand may get you into a hoot of trouble because of its own variables. As a matter of fact, I may jump on your tractor with a hitch just like I do my own and jump right off your tractor deeming that method too dicey. I have done this for 30 years not because I have simply been lucky as your wording intimates. If you want to phrase it that way, then I have survived my profession, marriage, 3 daughters (although that survival factor remains to be seen) or I am stilll alive in general because its the way I run my life. Variables are key here along with operator diligence. The guy pictured with his JD attaching his hook to his 3 point adapter may be just as safe as I am or he may not. Before coming down with a total condemnation, I would think some variables need to be considered. If we are to be educational in this forum, then all sides need to be looked at and people can then make up their own minds based on their own variables
   / How do you hook your Log tongs to draw bar? #42
Arrow we are not that far off in our thoughts. I am just concerned that new people looking for advice on skidding logs might choose this relatively risky method without being experienced and aware of the hazards.
We take risks everytime we get out of bed in the morning but it is nice to eliminate serious ones if we can. Flipping a tractor, as we all know, can happen to very experienced operators so setting up a tow/pull/drag to minimize that risk just makes sense. Operating slowly in known turf etc is one way to do that but as one is still vulnerable to some of the uncontrollable issues I still think it is best for people with less experience to avoid these "high hitch" methods altogether. I guess for me the point is mostly that there are alternatives that just require a bit of forethought/planning so why not send the new guys in that direction to begin with.
   / How do you hook your Log tongs to draw bar? #43
I am glad to see your movement on this subject meaning that your last post would have made a good first post. A couple of years ago it was I bringing up the point of questioning how safe or unsafe a seat belt was on a smaller narrow tractors that was operating in certain terrain or conditions. I got kinda beat up on my assertions but will always remember that if I had my belt on the day my tractor found a low spot in the front while climbing a high spot in the rear backing up, I might not be here today as the tractor flipped hard on its side where I would have surely bashed my head against the rock it came to rest on. Instead I was thrown/jumped from the seat and landed on my feet. Made me question blanket assertions such as "always wear your seat belt". Under certain conditions, it may be more safe to lift a log with a 3 point than to drag it on the ground pulling it with the hitch bar depending on terrain and the tractor. The very thing that may cause a tip over may also be the thing that provides a safe turn and that is the extra weight provided by a lifted hitch. This weight helps with traction and stability which may be just the thing needed on a given situation. That is on one hand. On the other hand, as I was journeying from my bil's house in Kentucky last week, ( where I cut grass with his JD 5325 and was sure to be belted in on that baby) while driving through West Virginia and part of Maryland, I opined on how would I care to skid logs through these hills and decided I would not. Talk about some variables
   / How do you hook your Log tongs to draw bar? #44
Greetings Learned Forum:
My brief visit to the Forestry Forum was pretty grim.
How is this for a thread title: "Logging with farm tractor=bad"
Here are some posts:
"a tractor is for farming, unless it is equipped with the right protection. i did it for a while, but i think a skidder is a lot better"
"logging with a farm tractor is very dangerous just a good way to flip one over on your self."
So I am not thinking I will find a lot of helpful hints on how to skid with one of our contraptions, other than buying a really nice logging winch for several thousand dollars.
Using a friend's borrowed Kubota L3400, I bet I have skidded at least 40 good sized trees, using a choke chain and a hook on the draw bar. I had no idea I was taking my life in my hands to such an extent. I was just wondering if there was an easier/more efficient way.
Nick
   / How do you hook your Log tongs to draw bar? #45
I have skidded logs with no problem. I wonder if they arent being used for lumber why bother? Might as well throw a chain around the center and lift it up a bit and cut them to legnth right there and then transport in the bucket.If I pull trees it usually becasue I want the brush in another spot so I drag it close cut it and the push the brush away.
   / How do you hook your Log tongs to draw bar? #46
Nick
Skidding is a pretty efficient way for a homeownwer or for a logger for that matter. I do not know what the odds are in terms of skidding on a compact tractor or driving a car on the road as it relates to a safety factor. According to all the safety eddicts that have come down the pike over the years, everyone over the age of 65 should be dead as they should not have made it thru childhood what with no helmets while bike riding, playing with fireworks, **** my first football helmet had no face bar. Anything you learn from this forum must be under consideration as from whence it came. Some guys get puckered up if their front wheels lift 6 inches off the ground and then state to all that would hear that they will never do that again for whatever caused it. You've skidded 40 trees, how'd that go? I personally think there are many more things you can do than skidding with a compact tractor to take your life in your hands. Use your own experience and common sense and don't let anyone here rattle you too hard. Remember, there are many people here who have brought over stems in just this way for many, many years with nothing untoward happening other than the usual aggravations when doing this sort of stuff.
   / How do you hook your Log tongs to draw bar? #47
Yeah, but keep in mind the ones that did not survive that experience tend not to post on TBN anymore. :p The fact that someone on TBN claims that going over Niagra Falls in a barrel is easy and safe because they have done it and survived is not exactly good evidence that your odds are good for surviving the experience.
Yes we are all here today despite growing up without seatbelts but we also know that without modern safety devices that there would be about three times as many road fatalities as there are today (based on comparison to fatalities per mile in 1960). That is about 70,000 deaths per year prevented by safety devices.
When safer ways of doing a dangerous task are developed it just makes sense to carefully reconsider your usual practice. Not everyone needs a skidder or logging winch but there are also ways to adapt a tractor so that flip over risk is minimized.
   / How do you hook your Log tongs to draw bar? #48
To the OP:
I attach my tongs to the inner mount on my boom pole - about 3' or 4' aft of the 3 point hitch. This gives good reach and height if the log isn't too heavy. I then hitch a choke chain from the butt of the log to the drawbar so I am lifting with the hitch and pulling with the drawbar. Belt & suspenders - I know - but based on the physics, that's just the the way I roll.
-Jim
I have read this thread with great interest, because the majority of my tractor use for the next couple of summers will be skidding logs. For those of you who do this routinely, what are you opinions on the best log pulling set ups? Sure, a Farmi skidding winch would be great, but I don't have the $5K for one. Keeping it simple (hooks, chains, lets say under $300) what is the best combination of safety and effectiveness?
Nick
How long does someone have to do something with a particular method before it is deemed "suitable". So if 20-20 has logged with his 3 pt for 30 years and myself have logged this way going on 30 years without incident, I would rather look at it as a reasonable risk in line with playing baseball or hockey or whatever rather than terming it "dumb" . There are some people who regard such risk as "dumb" even with protective gear. Island makes a good point about individuals and the info going out . One's survivability depends on one's own survival instinct. Many, but of course not all, of the horror stories you read about happen to people with lower instincts while others are quite cagey, calculating and careful. There are people who I know that I would not suggest them driving at all and there are people I would suggest not picking up a chainsaw not because both things are inherently dangerous but being more concerned with the personality of the person involved with the risk. Knowing variables is key to lessening risks.There are other varibles to consider when logging with cuts. I'm in an area where it snows. All of my skidding is done in winter which reduces surface tension. If one is in an area of non snow, a good set up may be using the 3 pt with a small arch at the end of the log being skidded.
It is always wise to preface any advice because of not knowing the operator's characteristics, temperment, abilities and equipment. There are reasons my tractor has not come close to being in a dangerous situation when skidding just as there are reasons why Roger 4400 had a pucker moment. The "whys" of things go a long way to staying safe when being involved with risk no matter what the degree one wishes to partake in whether going 300 mph in AA/fuel vehicle or going lion hunting while naked armed only with a knife. The higher degree of risk, the more the whys become important until you reach a point of saying the most important why of all...."why am I doing this" That point varies for everyone.
There is doing risky things safely by being painfully careful. There are also ways to have your cake and eat it too by thinking thru the Physics and applying it to factor out the bad stuff.
larry
   / How do you hook your Log tongs to draw bar? #49
I'm still reading and still come up with the same answer in my head, everyone is making good points but I still say the most important is the operator him/herself. Experience and learning is all ANY of us can do, practice and share our ways. I have pulled thousands of logs with tractors over the years and I still learn something new every time I hook another. Of course I like to watch and figure what is what while things are happening. Some folks think all they need to do is hook up, drop it in a higher gear then needed, pop the clutch and they're off never to look back just listen to their Ipod. I've fallen thousands of trees over the years also but, would NEVER consider myself a professional tree faller nor would I ever consider ANY other person one, IMO there is no such thing. Every time something to do with logging comes up there are to many varibles to ever have one way written in stone, other then PAY ATTENTION !!!!
   / How do you hook your Log tongs to draw bar? #50
On another note about all of the safety functions on machines, I'm noticing people are becomming LESS responsible as operators. I'm noticing more folks off in laa laa land while operating machinery instead of watching listening feeling how everything is running. I never listen to a radio etc... while running my machinery not even while plowing snow. I'm not saying it's wrong but I do see some really dumb{ooops there is that word} mistakes happening. So my question is if folks are over confident because of safety swithes A-B-C-D-E-F-G-H-I-J-K-L-M-N-O-P.......... then are they TRUELY operating the machine to the best of their ability? The presence of or lack of safety devices still does not help a bad operator.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2018 FREIGHTLINER...
Hyster H90FT 8,000lb Diesel Forklift (A55973)
Hyster H90FT...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
Rooster Weathervane (A55853)
Rooster...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56435)
2019 RAM 5500...
