How do you get at manifold bolts?
   / How do you get at manifold bolts? #1
OrtisEvans
Laytonsville, MD
Ford NAA, Farnall Cub, Kubota B2100
On my Cub and my NAA, the bolts/nuts attaching the combined intake/exhaust manifold are very hard to access. On the Cub, two bolts are easily reachable with a socket wrench. The others have part of the manifold directly infront of them so that I might get a socket on them, but no way to apply a handle. As I see it, I will have to use a box wrench and rotate a small fraction of a turn at a time.
Is there a trick that everyone except me knows? Or is this a question for Soundguy?
Best Regards to All
Ok, so I asked either a dumb question, or a difficult one.
   / How do you get at manifold bolts? #3
A ratcheting box wrench might speed things along if it will go in that small space.
   / How do you get at manifold bolts? #4
that or a bent wrench to get in to the recess.. or a hex headed socket that you can put a wrench on.
I've made a few of those.. short cheap pakistan socket with a nut welded to it.... then use a wrench on it
soundguy
Thanks - It isn't just Detroit that makes unnecessarily hard to service designs.
   / How do you get at manifold bolts? #6
there are wose.. believe me....
wait till you have to tighten the lower 3pt lift pin inthe axle trumpet... ( gotta pull the axle and trumpet, and then the chunk, if ya wanna do both sides.. :) )tart button dont screw into the shifter cover either.. that's a 'D' hole, and retainer nut is onthe bottom.. so shifter cover comes off.
not bad on that 4 speed.. not as fun on a 5spd though.finger twisters and knuckle skinners too.. :)
still, in general.. ford tractors are still among the easiest I've worked on.
soundguy
2024 Bintelli ActivEV Pulse Electric Cart (A51694)
2024 Bintelli...
2025 K2223G UNUSED Double Garage Metal Shed (A53117)
2025 K2223G UNUSED...
Deere 325G (A50123)
Deere 325G (A50123)
2007 KONECRANE SMV25-1200B STRAIGHT MAST FORKLIFT (A51406)
2007 KONECRANE...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
