How do you get at manifold bolts?
   / How do you get at manifold bolts? #1
OrtisEvans
Bronze Member
Laytonsville, MD
Ford NAA, Farnall Cub, Kubota B2100
On my Cub and my NAA, the bolts/nuts attaching the combined intake/exhaust manifold are very hard to access. On the Cub, two bolts are easily reachable with a socket wrench. The others have part of the manifold directly infront of them so that I might get a socket on them, but no way to apply a handle. As I see it, I will have to use a box wrench and rotate a small fraction of a turn at a time.
Is there a trick that everyone except me knows? Or is this a question for Soundguy?
Best Regards to All
Ok, so I asked either a dumb question, or a difficult one.
   / How do you get at manifold bolts? #3
A ratcheting box wrench might speed things along if it will go in that small space.
   / How do you get at manifold bolts? #4
that or a bent wrench to get in to the recess.. or a hex headed socket that you can put a wrench on.
I've made a few of those.. short cheap pakistan socket with a nut welded to it.... then use a wrench on it
soundguy
Thanks - It isn't just Detroit that makes unnecessarily hard to service designs.
   / How do you get at manifold bolts? #6
there are wose.. believe me....
wait till you have to tighten the lower 3pt lift pin inthe axle trumpet... ( gotta pull the axle and trumpet, and then the chunk, if ya wanna do both sides.. :) )tart button dont screw into the shifter cover either.. that's a 'D' hole, and retainer nut is onthe bottom.. so shifter cover comes off.
not bad on that 4 speed.. not as fun on a 5spd though.finger twisters and knuckle skinners too.. :)
still, in general.. ford tractors are still among the easiest I've worked on.
soundguy
2024 Polaris General XP 1000 Premium  (A52384)
2024 Polaris...
Tafe 45DI (A50123)
Tafe 45DI (A50123)
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
New Holland B95B (A50123)
New Holland B95B...
