jayste
- Joined
- Feb 12, 2008
- Messages
- 1,744
- Tractor
- 2004 Kubota M4800 SU
Along with all of the above good information you might tell them you are putting in your driveway and not just adding to an existing one. They can recommend a type of rock for the job. Preferably with some sort of "binder" which is what they call it around here. Basically, binder is a powder that is created when crushing the stone. It helps "cement" the stone in place when your drive gets rained on or wet down. Around here I've used what they call "Harjo gravel" or "native gravel" which is a gravel with a high clay content which makes for a great base for a driveway. My experience with putting down gravel without the binder as a base is that the gravel will eventually "sink" into the softened ground when the rainy season comes. After a good base is set you can always come back with some "clean" gravel and spread over that say in a year or so if you want to make it look a little better but sometimes it's not necessary. Happy Tractorin'!:thumbsup:
