Grapple How do you control your hydraulic grapple?
/ How do you control your hydraulic grapple? #21
I don't have one yet, but I'm working on it! :)
/ How do you control your hydraulic grapple? #22
I reversed my W.R. Long Valve button after reading this post! I knew it didn't feel quite right! It is now left to close and right to open on my grapple bucket.
The dumb thing is that how it was when I first set it up last month and I thought it was wrong. So I had reversed the hoses where they attach to the bucket. Then I kept pushing the button the wrong way. It does feel more natural now, but I still go the wrong way at times.
I haven't had time earlier but here is some photos of my grapple and setup.
ksmmoto
/ How do you control your hydraulic grapple? #23
ksmmoto
Pretty neat setup!
I'm sure you'r also aware that if your grapple couplers were rotated 90 degrees that they would allow the hoses to pull out of the female connectors should they snag on something. It might also be easer to attach and disconnect your hoses.
/ How do you control your hydraulic grapple? #24
ksmmoto said:
Ihaven't had time earlier but here is some photos of my grapple and setup.
ksmmoto
Nice set up. Where did you get the attachment fitting that holds the quick connectors to the FEL torque beam? I also like the armoured hose cover but haven't seen a source for that either.
/ How do you control your hydraulic grapple? #25
I bought my armoured hose cover from Discount Hydraulic Hose. It's listed in their Hydraulic Hose & Hose Ends catalog and prices range from $1 to $4 per foot depending on inside diameter.
/ How do you control your hydraulic grapple? #26
I saw the attachment fittings at TSC.
/ How do you control your hydraulic grapple? #27
Thanks Mad. Looks like 2" internal diameter cover would fit over a quick coupling and a 3/4" OD hose simultaneously so I could retrofit them on twin hoses without taking the couplings off. Is that about the size you bought?
/ How do you control your hydraulic grapple? #28
I bought 2". It handles 2 of the 1/4" ID hoses just fine.
/ How do you control your hydraulic grapple? #29
Unfortunately the nearest TSC is two plus hours away from me. I cannot seem to find it in the on line catalog either. Do you know what these attachment fittings are called? I could find an excuse to play hooky:cool: and drive to TSC but I'd hate to find out they didn't carry the things at the nearest store.
/ How do you control your hydraulic grapple? #30
PineRidge said:
Pretty neat setup!
Actually, looking closely that the photographs it doesn't look like he used quick connectors on the FEL torque tube junctions. I presume your comment was predicated on quick connects.
I'd not thought of the safety "valve" of allowing the quick connectors to be pulled apart rather than tearing the hoses. Is that a common practice? Anybody had experience?
/ How do you control your hydraulic grapple? #31
Rolando,
I don't know which grapple you have but with the Bobcat utility grapple I have left closes and right opens. If you change the leads on the switch it will reverse it for all attachments. I would either switch the flat-faced couplers on the hoses or switch the hoses on the cylinder.
dsb
/ How do you control your hydraulic grapple? #32
The clamp grabs the ring or outside sliding sleeve of the coupler, allowing you to push a connector together or pull it apart without touching the female end.
I think the clamp fitting was made by Pioneer. If so you may find it on their web site.
/ How do you control your hydraulic grapple? #33
Ksmoto if that's the correct spelling, Thats Nasty!:eek:
/ How do you control your hydraulic grapple? #34
The couplers are 1/2" Pioneers and the bracket is also Pioneer. I just bolted it on direct. I used 1/2" couplers because thats what the bracket fit. Also I have some other attachments I am working on that need larger hoses. My hoses from the W.R. Long valve are 3/8". The hoses on the grapple are 1/4".
Thanks for the heads up on the 90 degree hookup PineRidge. I didn't think of that at all. I could have used the 90 degree fittings and drilled the holes for the bracket different. Anyway I am not going to change it now.
ksmmoto
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
2019 Ford F-350 (A55973)
2019 Ford F-350...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2020 INTERNATIONAL LT625 SLEEPER (A59905)
2020 INTERNATIONAL...
2022 Fairbanks Nijhuis Commercial and Industrial Water Supply Pump (A59228)
2022 Fairbanks...
1761 (A58375)
1761 (A58375)
