Loader How do you check the hydro fluid
   / How do you check the hydro fluid #1
Chugbug
Central Ohio
BX25
Question??? I check the oil and hydro before every use but I found that when the 3 pt is dumped, the dipstick on the hydro shows too much but when I raised the 3pt it shows dead on. I've been checking the hydro with the 3pt raised and cold. Any thoughts?? Thanks
   / How do you check the hydro fluid #2
Raised and cold is how I always check it. It makes sense to check the level with the hitch raised, since it's assumed that it'll be up when you're servicing the machine and since up is the storage position.
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
Kubota RTV500 (A47384)
2003 PETERBILT PB 330 WATER TRUCK (A51243)
2003 PETERBILT PB...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
Toro ProCore 864 Series Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
