How Do You Care for Your Firearms?
   / How Do You Care for Your Firearms? #31
Oh, here is some write up I just found - interesting point about sperm whales.
That is an interesting link. I just bought some Mobil 1 ATF for the truck tranny. What I do not use I will try as a gun lube. I bet the leftovers in the bottle will last a few decades. :D
Shoot It Clean It. :thumbsup:
Having said that I have read that on 22's cleaning the bore can affect accuracy.
I am far more concerned with rust than fouling. But on something that is used for defense or food it gets cleaned after use.
For handguns I first clean with brake cleaner and then move to Hobbes. I do have a clean from Remington that I use but Hobbes just works. Then Rem Oil or one other brand which I just forgot the name. It only takes 10 drops of oil to lube the pistol. I use the oil that I cannot remember the name, to lube our wood stove door latch. That latch will squeek as the season progresses and a drop of the oil works wonders. Impressed how well and how long the oil lasts given how hot the stove gets.
Later,
Dan
   / How Do You Care for Your Firearms? #32
Hiya,
OK, here goes:
22 pistols, chamber and action cleaning only, never touch the bore as they will shoot horrible for 30 or so rounds until it gets filled with junk again. (proven in a ransom rest with my Walther GSP and Pardini SP, more than double the group size until the bores got dirty again)
22 rifles: same as 22 pistols
CF pistols Lead ammo, everything gets cleaned every 500 practice rounds and before a match. jacked ammo I go 1000 rounds of practice before a cleaning and of course, before a match.
Revolvers: same as the CF pistols except add a lot of chambers to the to-do list...
CF rifles:
Match bolt guns: butches bore shine to get the jacket fouling out or the RCBS electric bore cleaner, chamber brushed out, locking lug recess brushed bolt taken apart/firing pin inspected, magwell scrubbed.
Service Rifles: same as above with gas system cleaning and trigger group cleaning oiling.
They all get wiped with a gun cloth and put in a dehumidified safe.
For lube I use either breakfree CLP or some orange synthetic I got at a gunshow. For the 22 match pistols in the winter leagues I use either Deere spray graphite or a powered graphite product "lub-a-spray" (NAPA I think) on the bolts and receivers, works very well in low temps with no abnormal wear to any of the pistols after 12 years of use.
Tom
   / How Do You Care for Your Firearms? #33
I have a friend - he is chemical engineer working for a big oil company - and he uses ATF to oil his guns. I suppose it is preventative like any other oil. When I asked him if he is concerned about atf on hands and such while hunting, he said atf is almost consumption quality oil.
He's right. The original automatic transmission oil used a whale oil base. ATF is one of the primary ingredients of Ed's Red, a popular home brew bore cleaner and lubricant.
Ed's Red
I'ts particularly popular among black powder shooters, who have to deal with heavy and corrosive fouling.
   / How Do You Care for Your Firearms? #34
One other touch: I spray the inside of gun cases with a silicone spray lubricant. I also keep a rag either sprayed with silicone lubricant or oil in the case with the gun to wipe it down if salt or moisture become a problem. I have plenty of hard shell cases to haul guns around as needed.
   / How Do You Care for Your Firearms? #35
I mainly keep mine wiped down with oil, if they are going to sit for long periods I will pull an oiled patch down the bore just for insurance. When I get a new gun I thoroughly clean it to get the protective lube they use when packaging it. If you want a cheap and very effective cleaning kit check out Patchworm.com.
   / How Do You Care for Your Firearms? #36
WHILE WEARE HER...WHAT ABOUT A DEHUMIDIFIER FOR A SAFE..ops sorry:laughing:...i buy them disposable one occ but my safe is in the dining room and i dont think humidity is a problem with the a/c and the winter is so dry my nose bleeds...
i havent seen any rust but whats a good unit for inside and how does it work
   / How Do You Care for Your Firearms? #38
I mentioned the 5 lb. bag of silica gel I keep in the bottom of my gun safe. Silica Gel is a granular dessicant that absorbs moisture out of the air. When it gets saturated, just put it in a warm (225 degree) oven for a couple hours to drive the water out, and use it again. It works best in confined spaces, like the inside of a safe. The tighter the door seal the better.
   / How Do You Care for Your Firearms? #39
A small heater inside the safe will insure that moisture does not condense on the contents.
I used to use a light bulb, but now I use a small aquarium heater, the kind that is meant to stick on the bottom of an aquarium. I peeled the release paper off the sticky side and stuck it to an aluminum cookie sheet which acts as a heat sink and radiator. It runs slightly warm to the touch and has lasted for many years.
Almost every safe has a hole for an electrical cord to reach the inside.
While you are at it, put a power strip in there so you can have a light when you want it. Mine is as dark as a bat cave, and me standing in the opening, peering in makes it even darker.
   / How Do You Care for Your Firearms? #40
i bought a remington rechargeable dehumidifier for 24 bucks from sportsman guide
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52128)
REYNOLDS 100 - 8...
2020 KUBOTA RTV...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
John Deere 7720 Turbo with Head (A52128)
John Deere 7720...
Brent 420 Grain Cart (A50514)
Brent 420 Grain...
2014 Ford Explorer SUV (A50324)
2014 Ford Explorer...
