Snow Equipment Owning/Operating How do you break apart the auger gearbox?
   / How do you break apart the auger gearbox? #1
Searay45DB
Chadds Ford, PA
Kubota G 1800
My Kubota TG2742, which attach's to the front of my G1800 ate a rock...a big rock. Bunch of bent stuff. Now, I need to get the shaft input, the shaft that comes off the PTO and the fan is on, out of the gear box. The auger shaft just slid out, it was simply keyed. There are four bolts that hold the housing together, unbolted those, but doesn't want to split.
Help!
   / How do you break apart the auger gearbox? #2
Probably just a stubborn gasket or sealant. Pry, tap, and cuss. If all else fails, use the Force!
   / How do you break apart the auger gearbox? #3
I dont know your machine but check for a C clip, they often "hide", also if you bent a bunch of stuff you may have a slight bend that is causing the hang up. Good luck!
22008 (A51694)
22008 (A51694)
2014 XL SPECIALIZED TRAILER XL 110 HDG RGN (A52472)
2014 XL...
CAT Skid Steer (A50322)
CAT Skid Steer...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52748)
2014 Dodge Ram...
