Snow Equipment Owning/Operating How do you break apart the auger gearbox?
   / How do you break apart the auger gearbox? #1
Searay45DB
Chadds Ford, PA
Kubota G 1800
My Kubota TG2742, which attach's to the front of my G1800 ate a rock...a big rock. Bunch of bent stuff. Now, I need to get the shaft input, the shaft that comes off the PTO and the fan is on, out of the gear box. The auger shaft just slid out, it was simply keyed. There are four bolts that hold the housing together, unbolted those, but doesn't want to split.
Help!
   / How do you break apart the auger gearbox? #2
Probably just a stubborn gasket or sealant. Pry, tap, and cuss. If all else fails, use the Force!
   / How do you break apart the auger gearbox? #3
I dont know your machine but check for a C clip, they often "hide", also if you bent a bunch of stuff you may have a slight bend that is causing the hang up. Good luck!
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
2011 Liebherr L586 (A52748)
2011 Liebherr L586...
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
2018 Nissan Sentra Passenger Car (A51694)
2018 Nissan Sentra...
Seed Spreader (A50325)
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
