How do u add aux hydraulics to a MF 2605 4x4 ?
   / How do u add aux hydraulics to a MF 2605 4x4 ? #1
cmore
nw tn
traded MF135 for a 2605 4x4 &added a Mahindra eMax 22HST
If some one has installed aux/additional hydraulics on a MF 2605, I would like to know the details of how u did it. I have a 4x4 with loader and would like to install additional options.
   / How do u add aux hydraulics to a MF 2605 4x4 ? #2
I've got a 1533 that I too would like to have first hand details... They seem to be similar models.
   / How do u add aux hydraulics to a MF 2605 4x4 ? #3
Both single and dual remote hydraylics packages for your 2605 are available from MF. Installation is bolt on but the packages are not inexpensive.
SDT
I was aware of the MF options but was hoping some one had used power beyond to tap into the FEL hydraulics and used that source.
   / How do u add aux hydraulics to a MF 2605 4x4 ? #5
You can tap into the loader power beyond
   / How do u add aux hydraulics to a MF 2605 4x4 ? #6
If your hyd is open center and the loader valve has PB, then you can interrupt the line going back to the 3pt and add your new set of remotes with PB , be it 3 or 4 spool valve.
If you really shop around, you can get the valve with float spools, or detent spools, etc
All valve connections should be in series.
You can get the valve, hoses and fittings from Surplus Hydraulics.
I was hoping some one that has done it on this model, could give a little hand holding.
Anyone?
   / How do u add aux hydraulics to a MF 2605 4x4 ? #9
You have 3 hoses that carry the flow to and from your loader valve. One of those hoses is connected to the power beyond port. You will use that power beyond line to feed your aux valves. Take the tank line from your aux valves and tee that into the tank port line of the loader valve.
Not sure what else it is that you are looking for? :confused3:
I can set you up with a triple set for $1025 if that helps you out any.
Some place to start I guess. ;)
Thanks MtnView
So we have the power beyond, return to tank and I guess the third is the input. How do I tell them apart?
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A51247)
UNUSED CFG...
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
LMC LOT NUMBER 142 (A53084)
LMC LOT NUMBER 142...
