How do the wires come out of this plug
   / How do the wires come out of this plug #1
drizler
Platinum Member
It痴 at the base of the ROPS on my 1736 and I need to rewire it I can稚 locate the tiny tab:confused:
   / How do the wires come out of this plug #2
There are small strips of that metal tube (maybe only one, maybe two) that act as "arrowhead" anchors to keep the tube from pushing backwards --and out-- as you connect that plug to its mate. When that type of plug is first built, those strips pop outward to lock the metal inside the plastic housing as the tubes (plus their wires) are pushed into place.
You'll have to find a suitable tube, preferably metal, that JUST fits over the plug's tube, and push down over it to collapse those two arrow-things. Once that's done the plug's tube will pull out the back. Sometime a metal ball-point pen tube will work, but a hobby-shop piece of 1/8" brass tubing works quite well. Standard "Molex"-style wiring.
   / How do the wires come out of this plug #3
View attachment 657082 View attachment 657083
Thanks for a good explanation and the sketch with an actual example!
   / How do the wires come out of this plug #5
Wow, they actually make a tool for that...! Probably something I should have. (I'm accustomed to just using Yankee ingenuity...)
You're welcome for the explanation. (Can you tell I was a teacher?:) Really miss the ol' chalkboards!)
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A52748)
UNVERFERTH 330 -...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
CAT 973 (A47384)
CAT 973 (A47384)
GS-3246 MAN LIFT (A52472)
GS-3246 MAN LIFT...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
