How do I swap a Joystick for the two level system to control the loader...kit?
   / How do I swap a Joystick for the two level system to control the loader...kit? #1
DW5610
Odessa, Missouri
Ford 5610 II
I have a 1987 Ford 5610 II with a Great Bend Loader. Currently the loader is controlled by two seperate levers. I would like to put in a joy stick and free up the 2 sets of Hydraulic ports.
Any suggestions?
   / How do I swap a Joystick for the two level system to control the loader...kit? #2
You take the IN hose of the loader valve and install it into the IN port of the new joystick valve, and connect the OUT hose to tank/return line of new valve, and install the PB adapter and run the PB hose to the next valve.
You could use the old valve as a remote valve, but you really need a PB line from the remote valve.
You need at least a 10 GPM valve.
Hydraulics:
Type: open center
Capacity: 15 gal [56.8 L]
Pressure: 2500 psi [172.4 bar]
Valves: 1
Pump flow: 9.7 gpm [36.7 lpm]
Steering flow: 3.6 gpm [13.6 lpm]
This valve has both float and regen.
http://www.surpluscenter.com/item.asp?item=9-7401&catname=hydraulic
http://www.surpluscenter.com/item.asp?catname=hydraulic&item=9-7401-B
   / How do I swap a Joystick for the two level system to control the loader...kit? #3
Is loader currently controlled by an ind valve on loader or tractor rear remotes?
2022 Adams CLC-1013 Conveyor - New (A55302)
2022 Adams...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A53422)
2021 Chevrolet...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
