How do I swap a Joystick for the two level system to control the loader...kit?
   / How do I swap a Joystick for the two level system to control the loader...kit? #1
DW5610
Odessa, Missouri
Ford 5610 II
I have a 1987 Ford 5610 II with a Great Bend Loader. Currently the loader is controlled by two seperate levers. I would like to put in a joy stick and free up the 2 sets of Hydraulic ports.
Any suggestions?
   / How do I swap a Joystick for the two level system to control the loader...kit? #2
You take the IN hose of the loader valve and install it into the IN port of the new joystick valve, and connect the OUT hose to tank/return line of new valve, and install the PB adapter and run the PB hose to the next valve.
You could use the old valve as a remote valve, but you really need a PB line from the remote valve.
You need at least a 10 GPM valve.
Hydraulics:
Type: open center
Capacity: 15 gal [56.8 L]
Pressure: 2500 psi [172.4 bar]
Valves: 1
Pump flow: 9.7 gpm [36.7 lpm]
Steering flow: 3.6 gpm [13.6 lpm]
This valve has both float and regen.
http://www.surpluscenter.com/item.asp?item=9-7401&catname=hydraulic
http://www.surpluscenter.com/item.asp?catname=hydraulic&item=9-7401-B
   / How do I swap a Joystick for the two level system to control the loader...kit? #3
Is loader currently controlled by an ind valve on loader or tractor rear remotes?
2018 FREIGHTLINER BOOM TRUCK (A51406)
2018 FREIGHTLINER...
2014 CHEVROLET IMPALA 4DOOR SEDAN (A54313)
2014 CHEVROLET...
2015 Chevrolet Silverado 3500HD Ambulance (A52377)
2015 Chevrolet...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A52377)
2021 Interstate...
