How do I remove the fuel filter bowl locking ring?
   / How do I remove the fuel filter bowl locking ring? #1
ragkar
Platinum Member
eastern PA-lower Poconos
JD2320 w/R4 $21,100 w/7.16%off
The JD2320 operators manual instructs me to turn it counterclockwise. But normally with a right hand thread it would be turned clockwise as seen from the top.
I can't see any threads so that doesn't help. It's on too tight to turn by hand and a rubber strap wrench didn't work. I'm thinking that a oil filter wrench might be what I need.
I need to be able to remove the filter if I get fuel gelling or paraffin precipitation.
   / How do I remove the fuel filter bowl locking ring? #2
Ah, but it should be looked at from the bottom. That's the way the ring nut is threaded. It really shouldn't be very tight. Can you get a pipe wrench around the 'nut' while holding the bowl with your hand?
   / How do I remove the fuel filter bowl locking ring? #3
Might help to see the parts breakdown. You are wanting to turn the ring off that secures the hanging filter bowl, and they are normal right-hand threads. Get a grip on the ring item 24 and push to the left.
   / How do I remove the fuel filter bowl locking ring? #4
Mine took a lot to break loose. I probably sprayed Triflow or Kroil on part 24, the lock collar in hopes that it might help unstick things. I may have removed the whole assembly from the tractor to get a better grip on the lock collar. I do not recall if I used a strap wrench or a pipe wrench to break it loose. It sure would be nice if someone sold a spud wrench/spanner, kind of like what you use to remove that nut that holds the agitator or drum in a top loader washing machine. It was/is right hand thread. Part 24 came loose with less stuggle a few years later. Either I did not overtorque, or it was less years so it did not corrode together as much.
   / How do I remove the fuel filter bowl locking ring? #5
It should not be on all that tight. Water pump pliers worked for me. Gave me a good feel and just broke it loose with them (turning to the left). Then just unscrewed the locking collar by hand. Going back together make sure everything is clean. I put on just a drop or two of diesel to lubricate and hand tightened until it seated and then another quarter turn. No problems since (10-12 hours or so).
   / How do I remove the fuel filter bowl locking ring? #6
The ring on my 4010 fuel filter was impossible to turn by almost anything that I had. What I ended up doing (and do it all the time now) is to remove the entire filter/bowl assembly from its mounting on the frame. There's a single 12 mm bolt holding it in place. Then it's easy to rotate the whole assembly on the flexible rubber lines to/from it to get at that silly ring.
Ralph
2011 Caterpillar 299C Two Speed Compact Track Loader Skid Steer (A52377)
2011 Caterpillar...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
1999 KENWORTH T800 DAY CAB (A54607)
1999 KENWORTH T800...
205113 (A52706)
205113 (A52706)
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
