How do I protect rain gutters from ice damage?
   / How do I protect rain gutters from ice damage?
When the snow slides, it makes enough noise - it's a warning to step a little faster out of the way.
I don't have any doors, etc. that I am concerned with regarding a "snow dump" along that part of the building, which is south facing. The north face side has no gutters at all; therefore, no problems. However, the south side of the building is concreted-- so I need gutters to prevent spalling of the concrete.
I am guessing that what is causing the gutters to be torn up is freeze/thaw cycles. Maybe enhanced if frozen ice chunks break away or get pushed by snow. When the sun comes up and UV increases, it melts snow higher up on the roof. The snowmelt runoff, later in the day, freezes along the edge of the eave at the gutter. Repeat that a few times and now there is a dam/barrier which causes the whole process to amplify. The roof over the building stays a little warmer than the overhanging eave since it never goes below freezing inside the (insulated) building. The eave overhangs by about 3 feet, and with no heat in it, the roof immediately above it is an opportune place to freeze.
I admit I do not know for certain how to address the problem (yet). But at this point I don't think that putting the snow dams to prevent snow from sliding is going to affect that freeze/thaw process at all. If anything, I believe if the snow would slide off easier there would be less to contribute to a freeze/thaw cycle. The roof is 4:10 pitch which is a bit unusual and steep for a metal building, which are typically more flat.
   / How do I protect rain gutters from ice damage? #12
If you have gutters you need the guards otherwise the weight of the ice and snow will pull down the gutters.
As far as installing them it depends on the roof panels and how much snow you get. You would probably be better off with a bar type system.
   / How do I protect rain gutters from ice damage? #13
Plowhog, which roof panels do you have? Maybe a picture would help.
   / How do I protect rain gutters from ice damage? #14
Here is a picture of the type I made on my break then use the roof screws with the washer and screw into the high ribs.
   / How do I protect rain gutters from ice damage? #15
Around here when I see gutters on barns with metal or slate roofs the gutters are mounted lower then the ones on shingle roofs, the snow and ice is supposed to clear the gutter when it slides off. Even when it creeps off slowly there is usually a long curling projection that falls off.
   / How do I protect rain gutters from ice damage? #16
I add a layer of water softener chunks in the gutter to keep them open in winter.
I will get a photo posted when I return. I do have some spare material where I am now, so I can photo that tomorrow.
I know it is not a standing seam roof. Already regret that I did not purchase that option.
   / How do I protect rain gutters from ice damage? #18
In Austria where snow is part of winter in Alpine regions I have half pipe copper gutters with heavy cast underslung brackets on every rafter tail.
They are mounted low enough to be just under the line of fire but typical Alpine design is for low pitch so the snow doesn't come off in sheets.
The rafters are sized for this and snow provides insulation and wind shelter.
The half pipe can be left open on the ends or open with a chain to ground to direct water to a catch basin... often a bed of rocks.
Typical winter but with a mega storm expected and my 75 year old neighbor shoveling snow lightening the load on the cabin roof...
   / How do I protect rain gutters from ice damage? #19
I wonder if one of the gutter covers would help direct ice and snow off of the roof.
I doubt ice expansion is too big of a deal, but you might still get ice buildup and weight in the gutters.
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 68in Dual...
S/N: 1240824 (A55853)
1979 MACK R MODEL WINCH TRUCK (A55745)
1979 MACK R MODEL...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
2014 Ford F-150 Ext. Cab Pickup Truck (A55852)
2014 Ford F-150...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
