How do I move this thing?
   / How do I move this thing? #11
Total blockage would look to obvious, I'd go a partial block.
   / How do I move this thing? #12
You'd be surprised at what PVC will take. On the other hand, with any luck, the pipe will flatten out on you just as you start across the driveway. Then you can get tears of frustration going & tell the wife it'd already be moved if you had a tractor.
   / How do I move this thing? #13
I agree with Defective. Jack it up, put it on skids. I have used 4 inch abs to roll large Glulams weighing several hundred pounds. I think before moving it, you should screw some 2x4's for X bracing to keep it all together. Good Luck.
   / How do I move this thing? #14
Pipe rollers or disassemble it... We had someone give us a cedar one a little larger than that and it came apart pretty easy for transport. The bottom was triangles joined at the center and around the edge, and the sides were a series of panels. The top is another series of triangles that lean against each other at the top/center. the shingles covering the panel junctions came right off in a long strip and went right back on later. The only tricky part was getting the last two roof panels off, but a carefull support of one piece with a 2X4 to the ground while the other piece is removed makes this pretty easy. My wife, son and I disassembled it in about 2 hours, and we put it back up in an afternoon. Assembling the base in place also allows you the chance to get the base supports good and level.
I don't know how strong yours is, but I would not even contemplate jacking and rolling mine. I don't think it is structurally strong enough to handle the flexing that would result. The deck panels on yours are probably only held together by 2 screws on each side, one at the point and one at each base corner of the triangular panels. Since it has open walls, the sides don't have the shear resistance that a skinned shed wall will have. That roof section is probably nearly as heavy as the base platform so if things get tweeked to much, watch out...
   / How do I move this thing? #15
wrap the whole thing in shrink wrap, push it over, and roll it wherever you want it to go!
seriously, my vote is for beefing it up a bit and putting skids under it, then dragging or pushing it using pipe for rollers under the skids.
amp
   / How do I move this thing? #16
If you are worried about the strength of PVC pipe, try using the peeler cores that the box stores sell for fence posts.
Very nice round posts about 8' long, usually treated so they are green color.
Pointy on one end like a giant pencil, but make great rollers.
   / How do I move this thing? #18
I agree with all the suggestions for using various rollers and skids under the building. I have moved much, much larger structures than that with the same principle. To make it even easier to roll get four 2x4's or 2x6's and place a pair of them between the ground and the rollers (like railroad tracks). "leap-frog" the ground boards as the building moves. On level ground you could push that gazebo by hand. The ground 2x's will also protect your yard.
   / How do I move this thing? #19
From experience if you put some water on the board that are sliding across each other, these will be pretty slick and make it that much easier to move.
Wedge
   / How do I move this thing? #20
Maybe this is what people mean by skids...
I would make a "sled" for it if it is not a real robust deck jacking (3) 6x6 perpendicular (front middle & back), fastening it to those, then (2) 6x6 parallel outside the corners of the gazebo with a sloped front (like a bow) fastened to the parallel ones.
Then just pull the sled where you want it.
I am always amazed at people's ability to move intact structures without them going to pieces, but people do it all the time with no problems. Good luck with yours!
2015 Dodge 5500 4X4 Bucket Truck (A52128)
2015 Dodge 5500...
2013 JOHN DEERE 470G LC EXCAVATOR (A51242)
2013 JOHN DEERE...
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
H & S High Capacity Hayrake (A50515)
H & S High...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
