How do I keep rust out?
/ How do I keep rust out? #1
mdbarb
Northern California
B21
My barn is immediately adjacent to a salt water marsh.
The barn is reasonably weathertight.
I notice that things in the barn - tools hanging on the wall, metal storage cabinets etc seem to rust at an accelerated pace.
Is there something I can do inside the barn that slows down the process short of applying some coating to every surface?
I was imagining big rust eliminator salt lick kinda thing.
/ How do I keep rust out? #3
Is the barn floored?
I've found that a vapor barrier between the ground and your shop floor helps a lot, as well as ceiling and wall insulation.
I installed ALOT of foundation drainage and a thick vapor barrier.
The walls are board and batten redwood siding over OSB over suds. Inside is bare to the studs and at the ceiling I look up to the underside of the corrugated metal roof panels.
I could install insulation I suppose but dont see how this would curtail any rust.
The tractor and tools would sure like the insulation and central air. Maybe they would work harder!
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2500 GALLON INDUSTRIAL TANK (A62130)
2500 GALLON...
2017 PETRBILT 389 6X4  T/A SLEEPER TRUCK TRACTOR (A59908)
2017 PETRBILT 389...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
49"X58" WIRE MESH TAILGATE (A62130)
49"X58" WIRE MESH...
