Posthole Digger how do I keep from burying the auger when I use it
   / how do I keep from burying the auger when I use it #1
koerbdog77
I have a John Deere Model 790 (3o engine hp) and a countryline post hole digger. I am using a 6 inch auger. I run the tractor between 2000 and 2200 rpm. I also dig a foot or so and raise the 3 point hitch to clear the dirt and then I do that again about another foot down. Nevertheleess, ussually on the third dig when I try to raise the 3 point hitch the auger just keeps digging until the gearbox reaches the ground. It is very difficult to get the auger back out. Any suggestions?
   / how do I keep from burying the auger when I use it #2
First be really careful when you raise the auger out of the hole...be sure to throttle way down in case you pull up too far...believe me you do not want that auger flying around at warp speed and for sure you don't want anyone around behind you....You might try some spray paint on the auger at the point you want to pull up and just take it easy on your throttle and down pressure as you are getting close...otherwise you just fill in with dirt on the holes you go too deep.....all I know and I have drilled a bunch of holes over the years...In the dirt....LOL
   / how do I keep from burying the auger when I use it #3
Sounds like a combination of technique and ground conditions. If the auger catches and won't come up, shut off the PTO. You can try to rock it back and forth (by moving the tractor) while continuing to lift the 3ph. Even if it doesn't help, at least you won't have as much to dig out.
   / how do I keep from burying the auger when I use it #4
Sounds like you need to go just little bits at a time.
Go a tiny bit and pull it out, Go a tiny bit and pull it out, Go a tiny bit and pull it out...
Do you have plenty of ballast up front? Are you butt heavy?
That may be of issue as well.
Post up pics...
   / how do I keep from burying the auger when I use it #5
I would never run my PHD at 2000 RPM. If you run it at idle you have plenty of time to lift it up in time to clear it, my 18 PTO HP is plenty for a 12" auger even at idle and if I catch a rock or root the tractor might stop instead of tearing up things.
   / how do I keep from burying the auger when I use it #6
way too much rpm...
   / how do I keep from burying the auger when I use it #7
Cut your engine RPM back. With a 6" auger you are going too fast. Continue cleaning out the hole as you go.
   / how do I keep from burying the auger when I use it #8
Could it be that your 3 point is showing less holding strength when (almost) down?
   / how do I keep from burying the auger when I use it #9
it's showing too much rpm and digging to china...
   / how do I keep from burying the auger when I use it #10
I know that this is sort of a repeat answer-question.:eek: But have you ever even tried to dig a hole with the tractor at an idle? This would be my first thing to try to resolve your problem.
good luck ;)
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
UNUSED FUTURE FT-E48 ELECTRIC BICYCLE (A51244)
UNUSED FUTURE...
2015 Chevrolet Silverado 1500 (A50323)
2015 Chevrolet...
2007 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2007 Ford F-150...
