dragoneggs
Super Star Member
- Joined
- Jun 9, 2013
- Messages
- 13,627
- Location
- Seabeck, Washington
- Tractor
- Kubota BX-25D, Kubota Z122RKW-42
Hi Ron... what is the inhibitor?Not only does the concentration lower the freezing point but increases the weight. If you add enough calcium it will be thick like syrup. My old industrial refrigeration days we had applications that went down to -60 degrees F. That was over 50% calcium for a freezing point of -70; it was real thick and heavy. CaCl has to have a corrosion inhibitor added or it will rust. In a tire it would last a long time as their is no dilution over time. With the inhibitor the inside of pipe stays clean as a whistle. If it leaks then it starts to corrode stuff pretty fast outside the enclosure (tire in our case). Nothing will be heavier than CaCl per gallon. The 75% + fill is a most or your tractor will become unstable as it rolls around. The 25% space is for expansion in hot weather.
Ron
