Traction How do I engage 4WD on TC30
   / How do I engage 4WD on TC30 #1
Edgeofthegrid
Newport, Washington
New Holland 2006 TC30 HST FEL 4WD
Hey all, new member but I've looked on the forum before. Just bought a used TC30 FEL, seller had left it in 4WD and said he would bring the operator manual up soon. Long story short I sheared the pin/bolt on the FWD shaft at the rear U-joint trying to mess with a heavy wet snow bank. the rear U-joint slipped off the shaft, and I heard some banging (the shaft was still turning and knocking the undercarriage). OK re-inserted the u-joint and replaced the shear pin/bolt and that part is good. But was using it this AM and noticed the rear wheels slipping and it seems like the front wheels are not providing traction at all. OK I'm thinking it somehow got out of 4WD, but I don't know enough how to re-engage! There's a lever on the floor board near center/left that moves front/back (see pic) There's a diagram on the floor board next to the lever but is not clear. I'm thinking I either broke something in the transfer case as well or it's just in 2WD and I don't know how to reengage 4WD. I called seller but no joy. Any info helpful thanks!
   / How do I engage 4WD on TC30 #2
That is the lever.
From your description, and the picture, it looks like forward is 4WD, and aft is 2WD.
I have the older brother 1920, but mine is up and down.
Thanks fried1765, been out trying the levers, locking the differential, rears still slipping. gonna wait til I reach the seller.
   / How do I engage 4WD on TC30 #4
The way I read it...the lever goes toward the bottom of the picture for 4 wheel engaged...the lever goes towards the top of the picture for 2 wheel...
Thanks /pine, that's the way I read it too. Hard to tell what's front/back of tractor from pic. I am going to re-check the shaft to see if the shear pin/bolts on the front u-joint got sheared too and managed to stay on. Better get some more mechanic gloves....
   / How do I engage 4WD on TC30 #6
I have a Ford 1715 which to my understanding is the direct predecessor to the TC30, the biggest difference is one is Ford/NH blue and the other is NH blue. On mine the 4 wheel drive is engaged with the lever to the rear, sort of the default position because the lever is tucked out of the way, and disengaged with the lever to the front.
Thanks FrankRetired, is it easy to move the lever back/forth? mine is moving quite easy, maybe too easy. lifted the front and spun the tires, shaft moves easy fwd/rev whether the lever is engaged or not. any thots?
   / How do I engage 4WD on TC30 #8
On my 1720 to engage the FWA I loaded the transmission while engaging. It will shift into the FWA easier. The shift lever did not shift easily. Put the tractor in gear and while engaging the clutch pull the lever.
Thanks, my lever is moving too easily, perhaps I broke the internal linkage?
   / How do I engage 4WD on TC30 #10
Perhaps. It could be an external linkage. It should not be easy to shift. It is a mechanical linkage.
2013 John Deere 2210 Accudepth Field Cultivator (A52349)
2013 John Deere...
2006 Poly-Coat Tanker Trailer (A50774)
2006 Poly-Coat...
Redneck Predator 360 Hunting Blind (A50515)
Redneck Predator...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2018 CATERPILLAR 303E CR EXCAVATOR (A51242)
2018 CATERPILLAR...
2018 JLG SKYTRAK 6036 TELESCOPIC FORKLIFT (A51242)
2018 JLG SKYTRAK...
