How do I determine which gas engine i have on mf135
   / How do I determine which gas engine i have on mf135 #1
jjlanotte
Sunbury, Ohio
1969 MF135 Perkins Gas
Hey I just brought home my first tractor, a mf135 gas engine. I know there a couple different gas engines for this and im trying to determine how to tell which I have. The tractor SN is 9A 85558 and there is a number on the block 37111500/2. Hope that's enough.
   / How do I determine which gas engine i have on mf135 #2
According to tractordata.com your machine is a 1969 . Now is it a 3 cylinder or 4????? 3 would be Perkins and 4 would be continental.
Arent there 2 different continental engines as well? 134 amd 145?
   / How do I determine which gas engine i have on mf135 #4
Most likely you have the smaller 134 continental..
Ok so what I've gathered. The 37111500/2 is the casting number of the block for both perkins gas and diesel engines. Diesel is the AD3.152 and the gas, what I have AG3.152. Both are equally rated HP wise. Hope this helps someone else down the road.
   / How do I determine which gas engine i have on mf135 #6
Be glad you have the gas Perkins instead of the Continental gas engine, the Perkins is a whole lot stronger engine as far as how it is built.
   / How do I determine which gas engine i have on mf135 #7
^Got that right^:thumbsup:
Well thats great to know! I was already glad that it had a higher HP output than the continental.
   / How do I determine which gas engine i have on mf135 #9
Its also built out of a Diesel block. Mucho stronger.More better.
Sounds like I lucked out then on my near blind purchase of this thing.
SPEECO SPLIT MASTER 15 TON PORTABLE WOOD SPLITTER (A51248)
SPEECO SPLIT...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2020 JOHN DEERE R4023 LOT IDENTIFIER 87 (A53084)
2020 JOHN DEERE...
