How do I determine which gas engine i have on mf135
   / How do I determine which gas engine i have on mf135 #1
jjlanotte
Bronze Member
Sunbury, Ohio
1969 MF135 Perkins Gas
Hey I just brought home my first tractor, a mf135 gas engine. I know there a couple different gas engines for this and im trying to determine how to tell which I have. The tractor SN is 9A 85558 and there is a number on the block 37111500/2. Hope that's enough.
   / How do I determine which gas engine i have on mf135 #2
According to tractordata.com your machine is a 1969 . Now is it a 3 cylinder or 4????? 3 would be Perkins and 4 would be continental.
Arent there 2 different continental engines as well? 134 amd 145?
   / How do I determine which gas engine i have on mf135 #4
Most likely you have the smaller 134 continental..
Ok so what I've gathered. The 37111500/2 is the casting number of the block for both perkins gas and diesel engines. Diesel is the AD3.152 and the gas, what I have AG3.152. Both are equally rated HP wise. Hope this helps someone else down the road.
   / How do I determine which gas engine i have on mf135 #6
Be glad you have the gas Perkins instead of the Continental gas engine, the Perkins is a whole lot stronger engine as far as how it is built.
   / How do I determine which gas engine i have on mf135 #7
^Got that right^:thumbsup:
Well thats great to know! I was already glad that it had a higher HP output than the continental.
   / How do I determine which gas engine i have on mf135 #9
Its also built out of a Diesel block. Mucho stronger.More better.
Sounds like I lucked out then on my near blind purchase of this thing.
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
RYOBI 420V BRUSHLESS ELECTRIC 21" PUSH MOWER (A51248)
RYOBI 420V...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
18 Front Suitcase Weights with Brackets (A53472)
18 Front Suitcase...
