How do I check the hydraulic fluid level on a 4025
   / How do I check the hydraulic fluid level on a 4025 #1
skeezixsmith
Mahindra 4025
I have looked for over an hour (on this forum as well as online too)for the answer to this question and cannot find it.
I bought a used 4025 that had a small hydraulic leak on one of the FEL lines. I had the line repaired at a hydro shop and it's now on the tractor. It is no longer leaking but I have no idea how much fluid was lost before I bought the tractor. I watched some videos about replacing the hydro filter but they never showed how/where they checked the levels or added fluid.
I know it's probably a really stupid question.
It's my first tractor so I know nothing...
   / How do I check the hydraulic fluid level on a 4025 #2
Not totally familiar with your tractor, but the filling port for mine is on top of the reservoir by the 3 pt hitch. Cap is only 1½" diameter (at least on mine) The site glass is near the PTO spline (mine is on the right) coming from the reservoir.
I made a home made dipstick (Mahindra didn't provide one...dumb) to check the fluid level.
The good news is that with that small of a leak, unless it's been going on for months, you probably didn't lose enough hyd oil to make a difference. But definitely should check it. See your owners manual for the location of the site glass.
   / How do I check the hydraulic fluid level on a 4025 #3
on a 4025 it's on top of the transmission, just look down while sitting on your seat. remove it with a wrench, and there is a dipstick attached to the plug you just removed. You don't screw it back in to get a reading. Mine is a manual transmission.
-Simon
-Simon
Perfect. Thank you. I didn't get an owners manual when I bought it so was at a loss.
Unfortunately I didn't receive an owners manual when I bought it. Looks like this forum may be a lifesaver for me.
   / How do I check the hydraulic fluid level on a 4025 #6
Glad to help out. This is a fun place to hang out in sometimes...
-Simon
   / How do I check the hydraulic fluid level on a 4025 #7
Bad Boy has most of their manuals online to download as a PDF. I just purchased a brand new 4025 and I still downloaded the manuals just in case something happens to my hardcopies.
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
2016 MACK GU713 GRANITE DUMP TRUCK (A51222)
2016 MACK GU713...
